arizonajones Posted August 18, 2014 Report Share Posted August 18, 2014 Also..... where are the pictures of this new 720? Quote Link to comment
Justin Berni Posted August 18, 2014 Author Report Share Posted August 18, 2014 Also..... where are the pictures of this new 720? I'll post some today Quote Link to comment
720inOlyWa Posted August 19, 2014 Report Share Posted August 19, 2014 I didn’t get that this is a ‘honing in’ kind of process, where you do it repeatedly until you get there. At first, I just adjusted it once and that was it. I wasn’t too far off, but it wasn’t nearly perfect until I did it again and then again to get it nailed down just so. Holy cow- it made all the difference. Thanks (yet) again, datsunmike! Quote Link to comment
Justin Berni Posted August 20, 2014 Author Report Share Posted August 20, 2014 My mom stopped by oriellys for me to pick up some tranny fluid, I told her what I need, and when she's there she texts me "the guy says gl5 is even better" I told her nevermind I'll find it at napa or something. She argued with me for a minute that if the guy says it's fine it's fine, but I'm not gonna trust that douche, but, I would like to know what is different and why so many people say it's the same if it's not? Quote Link to comment
wayno Posted August 20, 2014 Report Share Posted August 20, 2014 My mom stopped by oriellys for me to pick up some tranny fluid, I told her what I need, and when she's there she texts me "the guy says gl5 is even better" I told her nevermind I'll find it at napa or something. She argued with me for a minute that if the guy says it's fine it's fine, but I'm not gonna trust that douche, but, I would like to know what is different and why so many people say it's the same if it's not? They want to sell you something, they are not going to make any money if what you want is not in their inventory, so they say what they need to, to sell you what they have. Quote Link to comment
datzenmike Posted August 21, 2014 Report Share Posted August 21, 2014 My mom stopped by oriellys for me to pick up some tranny fluid, I told her what I need, and when she's there she texts me "the guy says gl5 is even better" I told her nevermind I'll find it at napa or something. She argued with me for a minute that if the guy says it's fine it's fine, but I'm not gonna trust that douche, but, I would like to know what is different and why so many people say it's the same if it's not? GL-4 and GL-5 both contain sulphur compounds that forms a molecular bond on the outer layer of the gear teeth that resists scuffing. These same sulphur compounds will bond to the copper in the bronze alloy of our transmission synchronizer rings. The problem is that this layer is loosely bonded to the soft copper underneath it and it sheds. Slowly, layer by layer the copper is corroded or eroded away. GL-4 contains about 4% of these compounds and this is a low enough concentration to not overly react with the copper. Differentials contain no copper and so, GL-5 can be used which is about 6% concentration. Two percent doesn't seem like much you say? Well it's not 2%. The difference between 4 and 6 is 50%. Differential gears transmit power differently that transmission gears and they need more scuff resistance. Your transmission only needs the protection of GL-4. Yes GL-5 is better, but what makes it 'better' is also what makes it very wrong for out transmissions. 3 Quote Link to comment
arizonajones Posted August 21, 2014 Report Share Posted August 21, 2014 GL-4 and GL-5 both contain sulphur compounds that forms a molecular bond on the outer layer of the gear teeth that resists scuffing. These same sulphur compounds will bond to the copper in the bronze alloy of our transmission synchronizer rings. The problem is that this layer is loosely bonded to the soft copper underneath it and it sheds. Slowly, layer by layer the copper is corroded or eroded away. GL-4 contains about 4% of these compounds and this is a low enough concentration to not overly react with the copper. Differentials contain no copper and so, GL-5 can be used which is about 6% concentration. Two percent doesn't seem like much you say? Well it's not 2%. The difference between 4 and 6 is 50%. Differential gears transmit power differently that transmission gears and they need more scuff resistance. Your transmission only needs the protection of GL-4. Yes GL-5 is better, but what makes it 'better' is also what makes it very wrong for out transmissions. Mike this is awesome. We should all print this out and give it to the shops who say GL5 doesn't make any difference. Quote Link to comment
datzenmike Posted August 21, 2014 Report Share Posted August 21, 2014 Many newer transmissions have no copper alloy parts, maybe stel synchros? so GL-5 would be super to use. Unfortunately our older Nissan transmissions do not and need to be protected from GL-5. Differential gears mate differently and transmit power around a 90 degree bend. Maybe they slide across each other differently and need more protection. Transmissions transmit power in the sam axis direction. Quote Link to comment
81SVN20 Posted August 22, 2014 Report Share Posted August 22, 2014 I picked up some Sta-Lube GL-4 from Napa, how much fluid pints or quarts to put into the trans? Quote Link to comment
datzenmike Posted August 22, 2014 Report Share Posted August 22, 2014 Two liters or 4 1/4 US Pints. Quote Link to comment
81SVN20 Posted August 22, 2014 Report Share Posted August 22, 2014 Two liters or 4 1/4 US Pints. Thanks Mike I will be changing my tranny fluid along with the diff as well and got the amount for the diff you posted on the other thread... Quote Link to comment
datzenmike Posted August 22, 2014 Report Share Posted August 22, 2014 It's full when you can't add more. Quote Link to comment
_chiefjt Posted August 23, 2014 Report Share Posted August 23, 2014 Where the pics at though?? haha Quote Link to comment
Justin Berni Posted August 23, 2014 Author Report Share Posted August 23, 2014 Where the pics at though?? hahaSorry, havnt been doing much to the truck so I havnt been motivated to take pictures haha. This is all I have for now The kid before me was trying to be "JDM as fuck" and make the hood all rusted, probably the trend I hate more than any other, can't fuckin stand that. Quote Link to comment
Jeremiah720 Posted August 23, 2014 Report Share Posted August 23, 2014 I'm selling a weber if your looking for one. Manual choke has adapter plate for the 720. Go with the gl4 I just did mine not to long ago and it is better. same in my dif. I used a valoline brand, try not to use a synthetic it thins out more then normal and will seep out the seals. Quote Link to comment
Justin Berni Posted August 23, 2014 Author Report Share Posted August 23, 2014 I'm selling a weber if your looking for one. Manual choke has adapter plate for the 720. Go with the gl4 I just did mine not to long ago and it is better. same in my dif. I used a valoline brand, try not to use a synthetic it thins out more then normal and will seep out the seals. How much are you asking?? Quote Link to comment
_chiefjt Posted August 25, 2014 Report Share Posted August 25, 2014 damn that sucks. I could understand if it was natural patina but to force the patina......nah Bunch of noobs. haha You should've told him "Dude, it's not a Honda" lol I'm such a hater. Quote Link to comment
Fat510 Posted August 25, 2014 Report Share Posted August 25, 2014 How much are you asking?? Dude, there is a720 in Sherwood PnP with a really good Weber adapter plate right now Quote Link to comment
Justin Berni Posted August 26, 2014 Author Report Share Posted August 26, 2014 I'm ordering a weber today, but I think I'm gonna need a clutch slave cylender as well. Quote Link to comment
Justin Berni Posted September 1, 2014 Author Report Share Posted September 1, 2014 Weber hasn't come yet, but I gt my truck to stay running with my shit carb, ran bad but I got to drive it tonight and it was fun, my new 720 is so much quicker than my old one, maybe the extra 100,000 miles that the last one had made it a little slower from so much more wear on it? Anyways it was a fun night getting to drive for the first time in a while, weber will be even more fun. Quote Link to comment
Justin Berni Posted September 1, 2014 Author Report Share Posted September 1, 2014 Yes I know brake stands are harsh on the tranny and rear end and not very good to do, but I had to put this truck to the test. 1 Quote Link to comment
Justin Berni Posted September 3, 2014 Author Report Share Posted September 3, 2014 Finally, time for pictures. Front needs more low. rear could use another inch drop.. I love this bed liner. none ripped bench seat, and yes, a house speaker cuz it's all I have at the moment, it bumps tho, so it's actually awesome hahah. un cracked dash. I fuckin hate this rice lookin steering wheel, but I love my interior besides that! Quote Link to comment
wayno Posted September 3, 2014 Report Share Posted September 3, 2014 At least the back isn't full of shit right now. :lol: It looks good Justin, beware of parking lots, stay away from them, at least at night. :lol: 1 Quote Link to comment
Justin Berni Posted September 3, 2014 Author Report Share Posted September 3, 2014 At least the back isn't full of shit right now. :lol: It looks good Justin, beware of parking lots, stay away from them, at least at night. :lol: God dammit, too soon Wayno, too soon! hahahah Quote Link to comment
720inOlyWa Posted September 4, 2014 Report Share Posted September 4, 2014 Great looking little truck! It isn’t all tat hard to repaint a hood, if you wanted to. Quote Link to comment
