DrRocks0 Posted August 11, 2014 Report Share Posted August 11, 2014 Anyone know what oil cooler will fit in a 510 with a swapped Sr20? My replacement motor came with one but it's huge and can't fit anywhere. I just looped the hose back into the oil filter plate and removed it to get the motor installed. I would like to run one since the ports are there if possible. Google search came up with some cool pictures but no info on what cores they are running. https://www.google.com/search?q=datsun+510+oil+cooler&espv=2&tbm=isch&tbo=u&source=univ&sa=X&ei=--noU_bWJOqUjALL8oDYDw&sqi=2&ved=0CBwQsAQ&biw=1073&bih=991 Quote Link to comment
twistedimages Posted August 11, 2014 Report Share Posted August 11, 2014 I'm running an RX7 cooler in front of the valance: They're fairly easy to find, and give that great "Boso" look, if that's what floats your boat... Bungs on the ends are 18 x 1.5mm, and it's recommended to run -10 an line. 1 Quote Link to comment
DrRocks0 Posted August 11, 2014 Author Report Share Posted August 11, 2014 I still have the front bumper on mine, I don't think that would fit. That is the kinda look I was going to go for though. What year was that off of? Quote Link to comment
laotsu Posted August 11, 2014 Report Share Posted August 11, 2014 get a square fan cooled one and tuck it up under the fender Quote Link to comment
twistedimages Posted August 11, 2014 Report Share Posted August 11, 2014 I still have the front bumper on mine, I don't think that would fit. That is the kinda look I was going to go for though. What year was that off of? This is FC RX7 - 86-92, both turbo and non-turbo. Here's one with the bumper still in place- looks like it may have been modified, though! Edit: OK, yeah- that bumper was cut out for the cooler to fit above the spook. 1 Quote Link to comment
Big_E-Dog Posted August 11, 2014 Report Share Posted August 11, 2014 300zx one got it behind a headlight 1 Quote Link to comment
uberkevin Posted August 12, 2014 Report Share Posted August 12, 2014 I don't have a 510 but you can't do something like I did can you? Just use a longer one then me. Quote Link to comment
HEATHEN Posted August 12, 2014 Report Share Posted August 12, 2014 I put mine behind right highbeam. Quote Link to comment
datzenmike Posted August 12, 2014 Report Share Posted August 12, 2014 Got this for free from a zx TURBO automatic. Don't think the 5 speeds got them. Checked the fit on my 2.3 block, yes sir!!! Quote Link to comment
DrRocks0 Posted August 12, 2014 Author Report Share Posted August 12, 2014 With all the intercooler piping its a real tight fit in the engine bay. Behind the driver headlight is the intake and the passenger one is intercooler hose and radiator overflow. I'll post pics tomorrow morning of my engine bay. Where did you get that cooler? I might make that fit Quote Link to comment
HEATHEN Posted August 12, 2014 Report Share Posted August 12, 2014 Cooler is made by earls I think it is 8 inch. 1 Quote Link to comment
heywier427 Posted August 13, 2014 Report Share Posted August 13, 2014 ebay 30 row. fits perfectly behind the ebay ka radiator. Just had to fab up the brackets. go ebay. 1 Quote Link to comment
DISLEXICDIME Posted August 14, 2014 Report Share Posted August 14, 2014 Where you putting the ic? Quote Link to comment
heywier427 Posted August 14, 2014 Report Share Posted August 14, 2014 My bad, I have the dumbz. Staying n/a, so I see the dilemma with my placement... If/when I go kat, I would mount the oil cooler low, and run ducts off the spook and fab a forced induction face for it. something like this, but with the back open: P.S. I have an rx7 oil cooler laying around if anyone wants if for cheap. I modded it by flipping the mounting tabs so it would mount reverse, (meaning the oil lines would be on the other side). I wanted to put it up high and directly behind the grill, but unfortunately it did not fit in between the rad sup. and the front core brace. Just for a note, the rx7 oil coolers are very highly sought after because of the large volume of oil they hold/cool. Rotarys have very little room for oil in the block, so they made up for it with the cooler. so buy my shit :) 2 Quote Link to comment
Rawlo Posted August 15, 2014 Report Share Posted August 15, 2014 I have a rx7 one works good Quote Link to comment
paradime Posted August 15, 2014 Report Share Posted August 15, 2014 Run your SR with a good quality synthetic oil and you don't need a cooler. Synthetics can withstand temperatures of 300ºF all day long and still maintain proper viscosity and lubrication. Petroleum oil starts breaking down at 240ºF. If the thinking is to help cool the engine, you'd get a much better bang for the buck to run a bigger radiator, or a super strong fan with a tight cowl. Hanging a cooler totally exposed out in front of the car like that is great theater, but if you plan on driving this car it's asking for failure IMO. 1 Quote Link to comment
datzenmike Posted August 15, 2014 Report Share Posted August 15, 2014 All I can say is the oil runs much hotter because it goes hotter places the the water doesn't. The hot oil has to drop to the pan and be pumped all over the rest of the engine and the heat has to migrate to the water jacket first before it can be moved to the rad for disposal. There must be quite a time lag. A limitless supply of cooled oil will draw the heat away from these hard to reach hot spots more efficiently than the rad. 1 Quote Link to comment
DrRocks0 Posted August 15, 2014 Author Report Share Posted August 15, 2014 I found an earls cooler that I can fit under the bumper that will work. its this one: http://www.jegs.com/i/Earls/361/80700A/10002/-1?parentProductId=1676012 I have a new problem though. New clutch stopped disengaging the trans.. I drove the car for a few days with the new setup and it worked great, then one morning I drove to the store and almost couldn't get back because the clutch master died. It was original so I wasn't too surprised. I just replaced it and even though I bled everything I can't get the trans into our out of gear. I found the slave cylinder barely moves. I made a rigged adapter to the new master rod to get the clutch some more though and everything works. My question is: Does the 510 master cylinder have enough displacement to push the SR20DET slave cylinder? If so is this the sign that I need a new slave? It was a new slave from when I replaced the trans, but I don't know what brand it is. It was working find before. Checked clutch pivot, its good. Quote Link to comment
DrRocks0 Posted August 15, 2014 Author Report Share Posted August 15, 2014 FOUND MY PROBLEM. Need the 510 slave cylinder rod that is adjustable. I have the sr20det rod and slave and it is too short/too much freeplay. Quote Link to comment
