Nissan 710
Chemeris
Hello guys!
Maybe you know where I can buy all suspension components (kit) for Nissan 710 / Datsun 160J.? Front and rear.
From what car these components can be suitable? Or maybe you know company that produce the relevant details?
Sorry if a similar topic already was.
It's my car:
Suspension kit for Datsun 510:
  • Replies 3
http://community.ratsun.net/forum/54-610710/ start reading some of our members build projects. It's all in there. Also try the Project section and look for any 710s. You can lower your ride height and make it adjustable without expensive coil overs and firm up the springs for about $30 if you don't mind doing some work. The 280zx front struts can also be swapped onto your 710 as can the similar Maxima ones which is what I did on mine. Larger calipers and vented rotors. The rear can be dropped using lowering blocks you can make yourself.
