Colfax bee guy Posted August 2, 2014 Report Share Posted August 2, 2014 1975 620 checked horn buton connections in steering colum and under dash can't see anything that would cause it, HELP Quote Link to comment
datzenmike Posted August 2, 2014 Report Share Posted August 2, 2014 Likely a pinched wire. Grounding the horn wire activates the horn relay. Wiggle the wires under the dash and find the problem. The horn relay is up above the steering column behind dash cluster. Unplug the horns and honk the horn to locate it by it's clicking. Quote Link to comment
