DrRocks0 Posted July 31, 2014 Report Share Posted July 31, 2014 I thought I read somewhere that to swap an r200 from a 300zx into the 510 you need the diff and 2 driver side axles? Is this correct? I may have found a gold mine in San Diego Quote Link to comment
banzai510(hainz) Posted July 31, 2014 Report Share Posted July 31, 2014 R200s are heavy and bad gear ratio. and need more mods. Maybe a R180 from a 84 200sx automatic????????? 1 Quote Link to comment
DISLEXICDIME Posted July 31, 2014 Report Share Posted July 31, 2014 Google it . I broke an r180 with my sr 1 Quote Link to comment
Rjawm Posted July 31, 2014 Report Share Posted July 31, 2014 Google it . I broke an r180 with my sr Like he said... http://community.ratsun.net/topic/39258-r200-diff-in-510-w-zx-trailing-arms/ http://buildthreads.wordpress.com/2009/11/18/project-510-cv-driveshaft-conversion/ http://www.wolfcreekracing.com/index.php?option=com_content&view=article&id=22:tranny-a-rear-diff-parts&catid=16:tranny-a-rear-diff-parts&Itemid=31 1 Quote Link to comment
DrRocks0 Posted July 31, 2014 Author Report Share Posted July 31, 2014 R200s are heavy and bad gear ratio. and need more mods. Maybe a R180 from a 84 200sx automatic????????? gear ratio's are easy to swap. Quote Link to comment
banzai510(hainz) Posted July 31, 2014 Report Share Posted July 31, 2014 but have to mod the half shfts at least one side. R180 you just cut the dust cover on the 510 Hlf shaft or maybe 220z half shafts. Me and Icehouse did a R180 conversion and its EZ we made a vid but bababooey has it soemwhere hopefull he was going to load it up on You tube also seen Rich;s bluebird coup witrh a R200 also and it was done up good. I think needs a mustache bar mod also. 2 Quote Link to comment
DrRocks0 Posted July 31, 2014 Author Report Share Posted July 31, 2014 according to one of the guys who said he did it: this just from my experience with my previous 510, i installed a R200 into it and had a hell of a time getting it in the slot of the cross member, i even had to slightly flatten the spare tire well to get it to fit. then i had to modify the mustache bar because the two studs on the rear cover are spaced different from the r160. there was a write up on DQ about how to shorten the half shaft and how much, i think it was just under one inch, also shorten the plastic ball bearing spacer and remove one ball bearing per spacer or something like that, just don't quote me on this,LOL i didn't do any of that crap,LOL. i just slapped the stock 510 half shafts on and away i went. i never had any bottoming out that i knew of and just for the record i like my dimes dumped to the ground, i did have binding issues, but that was more from the massive u-joint angle i had from having the car so low.but that's just my 1 cents worth Quote Link to comment
DISLEXICDIME Posted July 31, 2014 Report Share Posted July 31, 2014 if you run stock shitty camber you dont have to shorten the half shaft but if you want to have any hope of traction you shorten it it is easy i did it a couple months a go . here is a pic http://album.hybridz.org/data/500/halfshaft.jpg you cut about 1/2 inch off the end then weld that washer with 4 nippels on the end there is write up some where on the net 1 Quote Link to comment
datzenmike Posted August 1, 2014 Report Share Posted August 1, 2014 gear ratio's are easy to swap. Done right they aren't. The non turbo 5 speeds and automatic 300zx up to '86,and all 300zx after were R-200 and 3.70 ratio which isn't too bad. The '84 turbo 200sx had 3.90 and the '85-'86 turbo had 4.11 both in R-200. Quote Link to comment
DrRocks0 Posted August 1, 2014 Author Report Share Posted August 1, 2014 if you run stock shitty camber you dont have to shorten the half shaft but if you want to have any hope of traction you shorten it it is easy i did it a couple months a go . here is a pic http://album.hybridz.org/data/500/halfshaft.jpg you cut about 1/2 inch off the end then weld that washer with 4 nippels on the end there is write up some where on the net Thanks! I don't want camber in the back if I don't have to. As it is the car is pretty slick. Done right they aren't. The non turbo 5 speeds and automatic 300zx up to '86,and all 300zx after were R-200 and 3.70 ratio which isn't too bad. The '84 turbo 200sx had 3.90 and the '85-'86 turbo had 4.11 both in R-200. I think the guy said it was from a 91 or a 96 non turbo automatic. I was really helping to go lower then the 3.54 that I have now. google machine poops out R200 long nose, 280Z, 280ZX, 300ZX Ratios 3.36, 3.545, 3.70, 3.90 LSD April 1987 and newer turbo Quote Link to comment
datzenmike Posted August 1, 2014 Report Share Posted August 1, 2014 I think the guy said it was from a 91 or a 96 non turbo automatic. I was really helping to go lower then the 3.54 that I have now. I assumed you wouldn't want to mod your 510 too much. These R-200s are much shorter than the stock length R-160s. Only the '89-'96 non turbo VG30Ds got the R-200 and all were 4.038 ratio and if LSD equipped they were of the viscous design Quote Link to comment
DrRocks0 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Oh, I thought long nose was all the same length. Lol the only piece that's stock on the 510 is the body. Everything else is replaced or modified. I bought it to tastefully mod it. Quote Link to comment
DISLEXICDIME Posted August 1, 2014 Report Share Posted August 1, 2014 i have a clutch type lsd from a z31. They are out there! But they are spendy in less you get lucky Quote Link to comment
510T Posted August 1, 2014 Report Share Posted August 1, 2014 but have to mod the half shfts at least one side. R180 you just cut the dust cover on the 510 Hlf shaft or maybe 220z half shafts. Me and Icehouse did a R180 conversion and its EZ we made a vid but bababooey has it soemwhere hopefull he was going to load it up on You tube also seen Rich;s bluebird coup witrh a R200 also and it was done up good. I think needs a mustache bar mod also. Yeah sorry Hainz I am going to work that out soon I promise. I just made an appointment with my techy pal... Quote Link to comment
HEATHEN Posted August 12, 2014 Report Share Posted August 12, 2014 the r200 diff cover alone makes you want to use this differential. 1 Quote Link to comment
DrRocks0 Posted August 12, 2014 Author Report Share Posted August 12, 2014 damn! CV conversion and everything! Quote Link to comment
DISLEXICDIME Posted August 12, 2014 Report Share Posted August 12, 2014 Are those Porsche Cv's heathen? Quote Link to comment
HEATHEN Posted August 13, 2014 Report Share Posted August 13, 2014 Yes Wolf Creek racing did the shafts. The install of r200 was a fairly straight forward swap. I struggled with finding the companion flange until I called the drive shafts shop they made the shaft for me. Quote Link to comment
