Andres131313 Posted July 29, 2014 Report Share Posted July 29, 2014 Ok so the only way I have been able to drive the car is to A.) have my foot on the gas enough to keep it running or B.) turn the idle screw in a lot. I looked at the bulls eye on the carb and it's 2 or 3 mm off the center. Also I have tried to mess with the mixture screw but I can put it all the way in (kills the engine) then all the way out and nothing changes. When I start it cold it will idle till I press the gas then it won't idle and it will just die. When I try to start it again it won't turn over until I press the gas to the floor. What is going on??? I have all the vacuum lines on. Quote Link to comment
Andres131313 Posted July 29, 2014 Author Report Share Posted July 29, 2014 How do I fix that? Quote Link to comment
EastBay521 Posted July 29, 2014 Report Share Posted July 29, 2014 first try by getting it started and putting your hand over the carb with the air cleaner off. had the same problem with my stock carb did that a couple of times was good after Quote Link to comment
datzenmike Posted July 29, 2014 Report Share Posted July 29, 2014 Listen near the back of the carb and have someone turn the key on off on off (don't start) You should hear a light clicking noise. This is the idle cut solenoid used on all L20B carbs to prevent run on. Basically an electric valve that shuts off fuel to the idle circuit when the key is turned off. If no clicking then it's not opening and letting gas through. It's the hex shaped thing with the red wire in this picture... If it's there but not clicking perhaps there is no power to it. Quote Link to comment
Andres131313 Posted July 29, 2014 Author Report Share Posted July 29, 2014 Just pulled it out and it works good. How do I get to the idle jets? Quote Link to comment
datzenmike Posted July 29, 2014 Report Share Posted July 29, 2014 There is no idle jet as such. There is an idle circuit with a screw that adjusts the amount of gas. This is the idle mixture screw that you adjusted. It may be part blocked. Bear with me. If the idle cut is working, carefully remove it. Don't loose the spring and washer inside. Get a can of carb spray, the one with the straw like the WD-40 can. Direct into the hole and give a good spray. Don't get in eyes. Now unscrew the idle mixture screw, (count turns) don't loose the spring. Spray into this hole also. Replace everything. This should rinse out the idle circuit, was cheap and most of all was easy. Try it. Quote Link to comment
Andres131313 Posted July 29, 2014 Author Report Share Posted July 29, 2014 DAMN IT!!!! Nothing like getting carb cleaner on your glasses and having the feeling your eye brows are on fire! I cleaned it all ( you don't know how hard it was to be able to spray the cleaner in the mixture screw hole) I'll try to start it in the morning. Thanks! Quote Link to comment
Andres131313 Posted July 29, 2014 Author Report Share Posted July 29, 2014 Started her up got scared because a huge cloud of smoke came out the carb. Didn't sound like it was missing anymore Quote Link to comment
