Question: Weber Swap
j_boy_619
My stock carb is giving out and instead of a rebuild i am deciding to just get a weber. A fellow Rat is selling one but its a 32/34 from an L series engine and i was wondering a few things:
1. Will it work?
2. How much tuning if any required? How much easier are webers to tune?
3. Can i use/modify the current linkage or do i need the weber links?
  • Replies 4
Not sure if the '75 is smog exempt yet? Will still not pass a visual inspection if ever required.
I doubt it will just 'bolt on'. It has to mount onto your intake and will need an adapter plate.
The B uses a cable throttle so if this 32/34 is from a linkage setup you'll have to adapt something.
Do some homework first. Be sure you get the air filter for it. It will be jetted slightly off for a smaller A14. The jetting kit isn't cheap and involves a lot of trial and error to find what works only to have a bunch of jets you don't need. Try to find someone that has already done the work and find out what jets he used and just buy them.
For under $50 I would rebuild the B's carb with a quality kit. Then save up for a weber.
