Corona521 Posted July 22, 2014 Report Share Posted July 22, 2014 so im looking for a carburetor for my '72 521, L16. any suggestions would help (brand, model #, place to buy, etc.) thanks Quote Link to comment
datzenmike Posted July 22, 2014 Report Share Posted July 22, 2014 Not much to replace it with, most L16s are getting scarce and well worn, but re-building is a cheap alternative. Get your hands dirty... so to speak. A new weber is about $300 but you get everything you need, gaskets, adapter plate, air filter etc. Weber Carbs Direct or Redline. A 32/36 would be more than big enough for an L16. Look for the direct replacement for an L16. I think the 521 had manual choke so you could skip the electric heater but they are convenient. Quote Link to comment
Ryan Family 510 Posted July 22, 2014 Report Share Posted July 22, 2014 I ran a 32/36 on my 1.8. My boys and I are putting a l20b In our 69. Budget wise I am looking at the same, 32/36 progressive. I swapped the progressive for 1 side draft, don't remember the size (1983). I'm thinking for a daily driver for my 16 year olds that the down draft progressive should work just fine for now, any thoughts on that? Quote Link to comment
Ryan Family 510 Posted July 22, 2014 Report Share Posted July 22, 2014 Just to clarify, I put a single side draft weber on the 1.8. I think it was a 38. It ran great! Don't want to spend that kind of money right now so looking at a progressive for the L20B. Quote Link to comment
TENDRIL Posted July 22, 2014 Report Share Posted July 22, 2014 32/36 and check the jetting, you will be ijust fine Quote Link to comment
EastBay521 Posted July 22, 2014 Report Share Posted July 22, 2014 if im not mistaken the truck came with a 32/36. it was missing the choke but it ran good.just spend 30 bucks on a rebuild kit and an hour to figure out and its good Quote Link to comment
Ryan Family 510 Posted July 22, 2014 Report Share Posted July 22, 2014 Figured, maybe when the boys are a bit older we will beef things up! 1 Quote Link to comment
Corona521 Posted July 26, 2014 Author Report Share Posted July 26, 2014 i've got several options, dont know which would work best. http://www.amazon.com/NISSAN-TOYOTA-ISUZU-MAZDA-CARBURETOR/dp/B000JLMTP4 http://www.ebay.com/itm/DATSUN-510-610-521-620-32-36-CARBURETOR-CONVERSION-KIT-NISSAN-NEW-CARB-/281305831463?pt=Motors_Car_Truck_Parts_Accessories&hash=item417f225827&vxp=mtr then there's three from weber carbs direct http://www.webercarbsdirect.com/Nissan_Replacement_Carburetors_s/37.htm what do you think? thanks for the help Quote Link to comment
datzenmike Posted July 26, 2014 Report Share Posted July 26, 2014 http://www.amazon.com/NISSAN-TOYOTA-ISUZU-MAZDA-CARBURETOR/dp/B000JLMTP4 .....Maybe. Doesn't say weber... http://www.ebay.com/itm/DATSUN-510-610-521-620-32-36-CARBURETOR-CONVERSION-KIT-NISSAN-NEW-CARB-/281305831463?pt=Motors_Car_Truck_Parts_Accessories&hash=item417f225827&vxp=mtr .....Run from this one. then there's three from weber carbs direct http://www.webercarbsdirect.com/Nissan_Replacement_Carburetors_s/37.htm ....Probably the best choice Quote Link to comment
67_1600 Posted July 26, 2014 Report Share Posted July 26, 2014 I got this kit from this seller on eBay. I'd go with them again if I ever needed another. http://www.ebay.com/itm/220748999279?item=220748999279&viewitem=&vxp=mtr Quote Link to comment
Sealik Posted July 26, 2014 Report Share Posted July 26, 2014 Buying from Redline will guarantee a genuine Weber http://www.ebay.com/itm/Weber-Redline-Carb-kit-fits-Nissan-Datsun-510-610-710-620-L16-L18-L20-1969-1980-/390858060981?pt=Motors_Car_Truck_Parts_Accessories&hash=item5b00f4b4b5&vxp=mtr Same as what 67_1600 posted.....but with electric choke Quote Link to comment
Corona521 Posted July 28, 2014 Author Report Share Posted July 28, 2014 where does the electric choke wire connect to? ive seen it connected to the alternator, and my current one is connected under my steering wheel? is it just a ground? Quote Link to comment
