bananahamuck Posted July 23, 2014 Report Share Posted July 23, 2014 Thanks for the clarification man. I will have to have FAT start on pulling the rear outta his parts car then. 1 Quote Link to comment
datzenmike Posted July 24, 2014 Report Share Posted July 24, 2014 May work.... It Works No.. I meant it in a light bulb goes on kind of way. 1 Quote Link to comment
Zeusimo Posted July 24, 2014 Report Share Posted July 24, 2014 I Can Get More Pictures This Weekend 1 Quote Link to comment
Charlie69 Posted July 25, 2014 Report Share Posted July 25, 2014 Are the axle flange bolts on the H190 spread out farther than the H195. These look like good durable brackets. Quote Link to comment
blackmarkit Posted August 1, 2014 Author Report Share Posted August 1, 2014 I beleive you mean H165 and H190. The H165 is a smaller bolt pattern. Im pretty sure the H190 uses the same bolt pattern as a 510 rear suspension. I had a good picture of the 2 different bolt patterns laid on top of each other to see the difference. but i decided to go swimming with my phone so no more picture. 1 Quote Link to comment
flatcat19 Posted August 1, 2014 Report Share Posted August 1, 2014 No answer to whether this will fit the H-150 yet. 1 Quote Link to comment
blackmarkit Posted August 18, 2014 Author Report Share Posted August 18, 2014 Someone measure the H150 bolt pattern in mm. H165 is 55mm x 74 mm bolt pattern. H190 is 56mm x 78.25mm bolt pattern. 1 Quote Link to comment
Fat510 Posted October 13, 2014 Report Share Posted October 13, 2014 Any updates? Because I really would like to buy these :geek: 1 Quote Link to comment
Charlie69 Posted October 13, 2014 Report Share Posted October 13, 2014 I beleive you mean H165 and H190. The H165 is a smaller bolt pattern. Im pretty sure the H190 uses the same bolt pattern as a 510 rear suspension. I had a good picture of the 2 different bolt patterns laid on top of each other to see the difference. but i decided to go swimming with my phone so no more picture. You are correct on my mistake. Bummer no more pictures. Quote Link to comment
Fat510 Posted April 20, 2015 Report Share Posted April 20, 2015 Still no updates? :( 1 Quote Link to comment
ggzilla Posted April 20, 2015 Report Share Posted April 20, 2015 Depends on which H190 axle housing you measure. Some have the same brake flange pattern as 710 H165 axle housing, but some are larger. The only cars that used H150 are B210 and B310 (210). Their axle housing's brake flange to hub flange distance likely differs from the 710's distance. 1 Quote Link to comment
invalidusername Posted December 31, 2017 Report Share Posted December 31, 2017 Thread revival: Are these brackets still being made by chance? I can't message blackmarkit. 1 Quote Link to comment
