Briansdime Posted July 17, 2014 Report Share Posted July 17, 2014 So I have a l16 with a dizzy off a l20b. Set everything to tech and have power everywhere but the plugs, turn it over and then found tdc again and the rotor is in a diffrent spot. Instead of #1 it will be on 3 or in between 1 & 3. The cam and pulley is on tdc but it seems like the rotor is jumping time. How do I fix this? Quote Link to comment
flatcat19 Posted July 17, 2014 Report Share Posted July 17, 2014 Did it get installed correctly? Even if dizzy is not set you should still see spark. You have a few different questions in your post, but are still quite vague on the issue. Quote Link to comment
flatcat19 Posted July 17, 2014 Report Share Posted July 17, 2014 Which L20B dizzy? The HEI or the matchbox? Which coil? Did you redo the wiring as well? 11:28 on spindle at TDC? Quote Link to comment
banzai510(hainz) Posted July 17, 2014 Report Share Posted July 17, 2014 if you time to TDC crank at zero and your dizzy is close to zero on timming plate and its inbetween 1 & 3 then mount you have maybe wrong. Did the dizzy come with the pedastal(mount)? the Matchbox had 2 types. One will fit the L20b point pedastal but the other will but it off between 1 & 3 thus you need to drop the oil pump and move the dist shaft. otherside of the dizzy is a 8mm bolt one can adjust the timming plate its enough to run but wont get top end power as youll cut out. also counter clock wise fire order Quote Link to comment
Briansdime Posted July 17, 2014 Author Report Share Posted July 17, 2014 Sorry it's a points dizzy, I have tried two coils the spindle is at 11:28 the first time I did the tdc. I get spark at the points but nothing out the plugs. When I get the points to open the rotor is in the middle of the pugs. Quote Link to comment
dr.feltersnatch Posted July 17, 2014 Report Share Posted July 17, 2014 Agreed with hainz. Probably the wrong pedestal. If at tdc the rotor point to the number 3 plug wire, then switch it so its now number 1. Then 342 in a counter clockwose direction. If it is half way between plug wires and you cannot rotate the dizzy enough to work you will have to pull the oil pump and rotate the drive spindle. Quote Link to comment
dr.feltersnatch Posted July 17, 2014 Report Share Posted July 17, 2014 Oh then disregard my post I assumed you were swapping in a matchbox. Quote Link to comment
Briansdime Posted July 17, 2014 Author Report Share Posted July 17, 2014 I have a matchbox but it dose not create spark have power to it and timed right just no spark. Oh and I took the valve cover off and rotated to line up tdc. I know there are different ways of setting it and from what I've seen it's at 1 and the mark is to the left of the v grove. Also I rotated it to the right and the Chain then had slack, is this common? If your looking at the front of the motor the right side of the cam gear is loose or what I have seen it's the straight part. Quote Link to comment
banzai510(hainz) Posted July 17, 2014 Report Share Posted July 17, 2014 TDC is off the crank. thats what your oil pump/ dist is based off of. What your doing is cam timming with the valve cover off. not related unless you took this aprt also earlier. Pu the point dizzy in and at 1128 spindal set the rotor should lock down. now where it points youll make that #1 pkug wire and go counter clock wise 1 3 4 2 fire order. the , I tried 2 coil is bad info. Hopefully its the stock point coil and still using the ballast resisitor and its wired right. olddatsuns.com tech section my vid part 6 should be on youtube Quote Link to comment
dr.feltersnatch Posted July 17, 2014 Report Share Posted July 17, 2014 With the matchbox how was it wired? The power side goes to switched power and negative side to negative coil. Its the negative side that fires your spark. Quote Link to comment
flatcat19 Posted July 17, 2014 Report Share Posted July 17, 2014 Points. Matchbox. Which is it? Quote Link to comment
banzai510(hainz) Posted July 17, 2014 Report Share Posted July 17, 2014 He updated with a L20 point dizzy I assume. I guess he had a matchbox as why update with a another point dizzy. Quote Link to comment
Briansdime Posted July 17, 2014 Author Report Share Posted July 17, 2014 Yes it's a points set up. Quote Link to comment
banzai510(hainz) Posted July 17, 2014 Report Share Posted July 17, 2014 So this means you got it figured out? Quote Link to comment
flatcat19 Posted July 17, 2014 Report Share Posted July 17, 2014 I'm so confused. GL with your issues. Quote Link to comment
datzenmike Posted July 18, 2014 Report Share Posted July 18, 2014 So I have a l16 with a dizzy off a l20b. Set everything to tech and have power everywhere but the plugs, turn it over and then found tdc again and the rotor is in a diffrent spot. Instead of #1 it will be on 3 or in between 1 & 3. The cam and pulley is on tdc but it seems like the rotor is jumping time. How do I fix this? If jumping around maybe the set screw that locks the timing plate is loose? Grab the dizzy and gently try to twist it. If it turns then it's loose. Sorry it's a points dizzy, I have tried two coils the spindle is at 11:28 the first time I did the tdc. I get spark at the points but nothing out the plugs. When I get the points to open the rotor is in the middle of the pugs. Same as above. Now put the EI dizzy and EI coil back on, it's way better than the points one. Quote Link to comment
Briansdime Posted July 18, 2014 Author Report Share Posted July 18, 2014 This may help with my problem. Quote Link to comment
flatcat19 Posted July 18, 2014 Report Share Posted July 18, 2014 Private video is private. Quote Link to comment
banzai510(hainz) Posted July 18, 2014 Report Share Posted July 18, 2014 http://www.youtube.com/watch?v=_aBTjhJMByo&list=PL8EF51386855F2B58&index=6 hope you hooked up the wires correct blk wht wire goes to the ballast then coming out of ballast will be the blk/blu or blk/grn what ever one you didn't pick coming out of the ballast will go to the + side coil. the blk/blu and blk/grn will be shorted under the tape Quote Link to comment
Briansdime Posted July 18, 2014 Author Report Share Posted July 18, 2014 Have no idea how to take it off private Quote Link to comment
datzenmike Posted July 18, 2014 Report Share Posted July 18, 2014 I see that you ion fact have an EI dizzy . You won't have spark at the plugs if the rotor is not lining up with the cap terminals. . Check for spark on the coil wire.... bet it there. Try turning the rotor by hand. I suspect the spindle drive gear on the crank is either missing it's woodruff key or it has sheared off. Has the front end timing gear been apart recently? Quote Link to comment
Briansdime Posted July 18, 2014 Author Report Share Posted July 18, 2014 I had the matchbox on just to see if it worked after I took the front cover off and readjusted the timing no spark. Same with the points dizzy have spark at the points just non at the plug. Also I do have spark at the coil. As for the gear that the dizzy runs off the crank I checked that and all looks good. I know I'm missing something. The points dizzy is off a 74+ 620, the guy that had it before me said it ran but a year ago so I don't know why after new plugs cap rotor it's not getting spark to the plugs. I've checked on both dizzy the gap and alignment to witch the spark is hit the cylinder and that's when I found that the timing was off a tooth judging by the slack in the chain. Quote Link to comment
datzenmike Posted July 18, 2014 Report Share Posted July 18, 2014 Distributor and cam timing are not connected. How can you check the spindle drive gear with the front cover on? Quote Link to comment
Briansdime Posted July 18, 2014 Author Report Share Posted July 18, 2014 I had the cover off when I did the timing chain Quote Link to comment
datzenmike Posted July 18, 2014 Report Share Posted July 18, 2014 At any time was the lower crank sprocket off? Maybe the crank pulley is slipping on the crank then. It was off and maybe the keys fell out installing it. Turning the pulley by hand moves it and the timing mark out of position. Lock the cam sprocket with something so it can't turn. Try rotating the front pulley by hand again. Quote Link to comment
