The Redskunk '73 620
  • Replies 63
I've been busy with work and other stuff. I haven't had personal time with working on the wiring and working on the truck. Other than that, I still need to re-do the engine harness too. But more to come maybe this weekend, I need to stop lagging and get this truck running again.
So after the long slow process of getting the wiring layed out and heatshrinked (loomed), I'm finally crimping the terminal pins for the circular connector. I ordered some male and female pins for my Souriau circular connector awhile back through Allied Electronics. I didn't realize how expensive the special crimping tool was. I ditched the idea of buying the crimp tool and went to Fry's Electronics to find a cheaper alternative. So I did. The cheaper generic crimp tool I found works okay on crimping the tiny pins onto the wire, with some extra effort of using a needle nose plier. But below are pictures of me attempting to finish the harness.
The first one I did. And it was a success! I did a twist and tug test to ensure the pin and wire was crimped tightly. So far so good! :thumbup:
Heres the pin remover I bought for a few bucks and customized. The Souriau pin remover was kinda pricey. But this does the same. It alows me to modify my harness in the future if i ever need to.
Here's a template diagram I created using Illustrator. I'm using it to map out where I want the pins to seat in.
I found time this labor day weekend to put the dash back in. There are still some wiring for the brake light and emergency brake switch wires I have to clean up. As you can see, they are dangling under the dash. But for the most part, I got the main dash harness set and ready to be plugged in.
The custom plate and connector I built.
Here's how it looks on the inside. (I've already mapped out/inserted the wiring and pins into the connector)
So....no progress lately. I'm itching to get this done soon. I've been going to the junkyard lately, and collecting parts and miscellaneous stuff. But I will finish up the engine harness soon. And more pics. Then afterwards, either cleaning or upgrading the fuel tank and carburetor.
As much as I wanna get this truck running and done, I just don't really have time/money/motivation for it anymore. The weather is beginning to get cooler. I'm just afraid of it sitting over the winter. But today I just found some inspiration on doing some more work. Just when I almost gave up and forgot about my truck, a new part came in. :D
The MONEY SHOT!
Finally, the engine wiring harness begins (after a long ass time). I found some time last night to get some stuff done. I made some wire labels to organize the wiring. They are ready to be heatshrinked. Oh, and on top of that I was able to find a replacement door and single glass rear windshield from a donor truck. I'll keep you guys updated...
My crimp tool sucks, I had to work with what tools I had.
More labels...
I like the labeling detail you are using.  Where did you source the plug you are using?
It took me a while to find an inexpensive circular plug connector. I bought the parts from Allied Electronics. There are other companies that supply them too, but you just gotta find what you want. I wanted to get a Mil Spec metal connector by Deutsch but they get very expensive, and the tools cost way too much. You can also check out ChaseBays on chasebays.com
Dont want to bust your bubble to much but You sure that connector wasnt made for female pins???? Ok really you should use female pins on that Connector.100% positve!
Male the pins would be sunk more back, the rim around it would be flush to the edge
Look s like a cheaper MS or Amphonol type connector(all work good)
as female pins feeds the POWER side. amde male will be the receptacal as female are protected to pins dont short out on the metal.
scanning back a page the bulk head coonector on the fire wall would use the male pins and it would be flush with the outer rim (round part ) but not excedd the height of the rim
Doh! You're right banzai510(hainz).... I just realized that....I think to save me time on having to cut the wires and re-pin the wall mount receptacle and the cable connector, I'm gonna have to order a new wall mount receptacle that accepts the female socket contacts and a cable connector to accept the male pin contacts.
I was also thinking maybe de-pinning all the female and male contact pins. Flip both the connectors around and re-pin them back in to the proper connector...
So I ordered new connectors from Allied Electronics to fix the problem. Good thing is that they did have the connectors to solve this mistake i made. I originally ordered part number: UTG01823PN & UTG61823SN.
But to correct this small issue i made with the pin inserted into the wrong plug, I had to order part number: UTG61823PN & UTG01823SN
