think my engine blew up today
H20doctor
  • Replies 34
At the least the seat would hang up the valve and it won't close properly. Revved long enough the seat might break, dropping pieces down the bore. The piston would slice and dice it into the soft aluminum head. The valve might snap off and punch through the piston....
well today i found the reasons for the knocking noise....drumroll please ...... i threw a 18 mm socket on the cam timing sproket put the bolt in and rotated the cam... exhaust valve on cylinder 4... no close ... stuck... siezed... going nowhere....  #4 piston has a tiny chomp in it, not a smiley chomp or a crescent moon shape, small indent mark... So there Ya have it winner winner chicken dinner , stuck valve
No, the valve can be removed without that. You will need enough space to compress the spring and remove the keepers. You may have to lightly tap the valve down onto the seat to do this, then drive the valve out of the guide.
