BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 get to the finished SR20 swap pics already .... :rofl: its not finished yet actually.. ): currently working on it everyday trying to get it going! but im almost caught up with pictures lol so be ready :thumbup: Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 Time to pull the car inside, literally! :lol: Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 So about a week ago a truck showed up with my Sr20 :w00t: Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 WAY TO MUCH JUNK ON THIS MOTOR sooooo, had to get rid of some stuff. about 30lbs of crap lol had to keep the A/C pump though just incase i decide to hook up to a underdash unit, because the valley is too damn hot! Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 little curve ball for you guys that might be following this Sr20de+T so i had to start somewhere and got a turbo header.. Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 Separated the motor and trans so i could pull the pan for my turbo oil drain line layed it on its side drained whatever oil was in there etc 1 Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 Drilled and tapped the block for the drain, came out nice also got the turbo oil feed line figured out and put on! Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 Wastegate & intercooler ! no more battery box, had to go for the intercooler, ill come back to this and clean it up just temporary Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 pulled the headlights to make more room for the intercooler then this happened lol and then this Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 The intercooler is going to fit nicely around my radiator Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 So the grill had to be modified... but i like the way it looks just needs a little adjustment and will be good to go Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 I feel like my car is out of place at the shop lol Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 Set the motor in just to get an idea of where it sits and fits Quote Link to comment
BlueCoupe Posted July 18, 2014 Author Report Share Posted July 18, 2014 TODAY : finally caught up ( left a lot of pictures out but oh well ) pulled the cross member, not going to flip going to box the ends and put some tube in there Quote Link to comment
BlueCoupe Posted July 21, 2014 Author Report Share Posted July 21, 2014 Hopefully today i will get the cross member cut up and finished and hopefully get the radiator mounted. Quote Link to comment
BlueCoupe Posted July 22, 2014 Author Report Share Posted July 22, 2014 Heres the new Cross member! Quote Link to comment
BlueCoupe Posted July 22, 2014 Author Report Share Posted July 22, 2014 Motor and trans are in! next is to make a new trans cross member. & cut the tunnel for my shifter Quote Link to comment
BlueCoupe Posted July 25, 2014 Author Report Share Posted July 25, 2014 in tank fuel pump setup 1 Quote Link to comment
BlueCoupe Posted July 29, 2014 Author Report Share Posted July 29, 2014 Time to flip the steering to clear the sr20de oil pan better flipped! Quote Link to comment
BlueCoupe Posted July 29, 2014 Author Report Share Posted July 29, 2014 Now its time for all the fun stuff.... wiring... Quote Link to comment
BlueCoupe Posted August 14, 2014 Author Report Share Posted August 14, 2014 So, cant figure out my wiring.. Ive used every sr20de wiring harness/pinout on the internet. Two weeks on looking and trying. Ive got to be close though.. sense everything is hooked up in the engine bay i decided to run everything into the cab and get my ECU mounted so i can stop twiddling my thumbs lol Here is a picture of my ECU just in case anyone else on here has it and could help lol i will admit its definitely similar to a lot of the other pinouts and whatnot but still has alot of differences Quote Link to comment
BlueCoupe Posted August 31, 2014 Author Report Share Posted August 31, 2014 Finally figured out the wiring not i just have to make it look pretty lol Quote Link to comment
BlueCoupe Posted August 31, 2014 Author Report Share Posted August 31, 2014 Got my radiator mounted the other day Quote Link to comment
BlueCoupe Posted August 31, 2014 Author Report Share Posted August 31, 2014 Picked up a throttle cable and some BA gauges from a pick n pull yesterday These are by far the coolest gauges ive ever seen, look 10x better in person Guages are made by VDO out of a 924 Porsche Quote Link to comment
BlueCoupe Posted September 14, 2014 Author Report Share Posted September 14, 2014 Going to hold off on the turbo for a minute got to modify the stock mani. Fits like a glove now! 1 Quote Link to comment
