red13 Posted November 23, 2014 Report Share Posted November 23, 2014 Nothing cant wait to get some time to work on mine again., Quote Link to comment
red13 Posted November 23, 2014 Report Share Posted November 23, 2014 Took the fenders off, every single bolt broke and are stuck now :sleep: A pic of my brothers e30 and friends skyline drifter , before I started taking fenders off And with a bunch of cars parked everywhere in front Hopefully you can get those bolts on the fender out. On my truck the PO decided to weld the fenders on. 1 Quote Link to comment
abbylind Posted November 29, 2014 Report Share Posted November 29, 2014 Drove mine in town for some errands...brake pedal went to the floor! Found the rear reservoir was empty...Stopped by Pep Boys and refilled with fluid. Pumped back up solid by the time I drove home. Further inspection found my right front hose has a small leak at the crimp. I replaced the wheel cylinder because in was leaking earlier didnt notice the hose. Replacing all hoses now.... 1 Quote Link to comment
Jersey Posted December 1, 2014 Report Share Posted December 1, 2014 Relocated my pull handle. 1 Quote Link to comment
hvyd Posted February 10, 2015 Report Share Posted February 10, 2015 It's been a long while since I've posted anything, let alone pics. Anyway, took my old exhaust valves and made danglers instead of using a pair of nuts like others and i finally got my rims on. 1 Quote Link to comment
red13 Posted February 10, 2015 Report Share Posted February 10, 2015 Forgot to post these the other day 1 Quote Link to comment
abbylind Posted February 11, 2015 Report Share Posted February 11, 2015 Drove it into town today...runnin like a scalded dog until.....banging noise in the rear...then a growling noise ....gotta be the drive shaft or the rear diff....damn something else to do... 1 Quote Link to comment
Madd Engineering Posted February 11, 2015 Report Share Posted February 11, 2015 marked the back edge of the cab to cut and weld it so i can fit a 720 gas tank 1 Quote Link to comment
ownTer Posted February 14, 2015 Report Share Posted February 14, 2015 Starting to tinker with stereo stuff.... Made a small enclosure for a 8" sub behind the seat..... Also started making small spearker pods for under the dash. Dont want to cut any holes anywhere. So trying other ideas Driver side.... Passenger side..... Trying to figure out a decent option for stereo mounting. Have the stock AM radio installed the hole. And would like to keep it there. Also not wanting to spend $100 on a center console. Unless someone has one for cheaper. Does not have to be perfect. Im happy to spit and polish parts up. None the less, take care and thanks for looking! 1 Quote Link to comment
ownTer Posted February 20, 2015 Report Share Posted February 20, 2015 Ordered wheel adapter so i can get rid of what feels like a wagon wheel that is my steering wheel. At 6'3" its a little cramped. I have a standard Grant in my Jeep i will recycle for the truck. Also have a couple side mirrors on the way. Swap out the giant one's that are on there currently. While i like how easy it is to see behind me. I need something a little cleaner. Been sanding and painting as well. Getting there, a little at a time. Ive found a few pin holes. And some decent sized holes in the doors. Other than that no major rust to speak of. Not counting floor pans of course. But the Mrs's has given the OK to buy a MIG set up. So ill be able to get all that type of stuff fixed here soon enough. Here's a pic I have some stock wheels and hub caps i painted up. I like them better but they do not fill out the wheel wells like these do. Need some spacers in the future so i can run them. Or lower it some more. But im already on 3" blocks and turned all the way down. And i kind of like the ride height its at now. Not too low. Still on the hunt for center console as well. So i can get some tunes going. May be a guy kinda local that has one. But have not heard back from him yet. So if anyone has one they would want to part with? Shipping to 98368. Thanks have a great one! Quote Link to comment
ownTer Posted February 21, 2015 Report Share Posted February 21, 2015 Ding...... I must say im very please after a test drive..... 3 Quote Link to comment
Charlie69 Posted February 21, 2015 Report Share Posted February 21, 2015 Looking good keep at it. Quote Link to comment
HOGIE Posted February 23, 2015 Report Share Posted February 23, 2015 In the last few weeks painted and installed recently dipped and repaired fuel tank, ran new fuel line, reinstalled, radiator, alternator, starter, distributor, new slave cylinder( thanks Al), coolant, tranny fluid, oil filter/oil, gas, bleed the clutch, wired up everything and turned the key for the first time in 9 months........fuck I need a carb kit. To lean. 1 Quote Link to comment
HOGIE Posted February 24, 2015 Report Share Posted February 24, 2015 Replaced the accelerator fuel pump and put in a new fuel filter. Messed around with the idle adjustment screw and got it to idle, it revving a little high and I need to adjust the timing some more but...its idling. Edit: <iframe width="560" height="315" src="https://www.youtube.com/embed/nq4WQpgKkss"frameborder="0" allowfullscreen></iframe> that is an embedded link from youtube but its not showing the video, wtf? 2 Quote Link to comment
TIGrant Posted February 24, 2015 Report Share Posted February 24, 2015 I finally painted my header with high temp. ceramic paint and I'm starting to put everything back on. Decided to replace the original bolts and studs with some InoX stainless studs off of Ebay from Jon's Auto Shack. Once I get this thing running I will probably pull the engine to do a thorough cleaning of it and the engine bay. 1 Quote Link to comment
ownTer Posted February 24, 2015 Report Share Posted February 24, 2015 Installed center console and stereo. So happy! Thanks Ted. Hes a member here but cannot remember his forum name.Will post a pic or two after its cleaned up. Had to do a bit of bondo work, the hole that someone else cut was a tad big. 1 Quote Link to comment
hobospyder Posted February 25, 2015 Report Share Posted February 25, 2015 Installed center console and stereo. So happy! Thanks Ted. Hes a member here but cannot remember his forum name. Will post a pic or two after its cleaned up. Had to do a bit of bondo work, the hole that someone else cut was a tad big. tdaaj? 1 Quote Link to comment
hobospyder Posted February 25, 2015 Report Share Posted February 25, 2015 Changed her spark plugs, cranked her and tried to put on the nos datsun 1600 badges. Also pulled fuel sending unit o-ring and keeper out of toolbox 1 Quote Link to comment
ownTer Posted February 25, 2015 Report Share Posted February 25, 2015 tdaaj? I think so. Very nice guy. Hope to get the chance to meet more of you all soon. I guess he had done some work on the truck i have. Or at least some parts he had were installed onto it. 1 Quote Link to comment
hobospyder Posted February 25, 2015 Report Share Posted February 25, 2015 I think so. Very nice guy. Hope to get the chance to meet more of you all soon. I guess he had done some work on the truck i have. Or at least some parts he had were installed onto it.he's a good guy. Had a work party on the seventh, he's got a lot of parts 1 Quote Link to comment
ownTer Posted March 1, 2015 Report Share Posted March 1, 2015 Center console installed... 2 Quote Link to comment
ownTer Posted March 10, 2015 Report Share Posted March 10, 2015 Stock shoes.....Quick paint job and tossed them on today. I like them better.... My other set is up for trade.... 3 Quote Link to comment
Eccles Posted March 10, 2015 Report Share Posted March 10, 2015 drove him to work 1 Quote Link to comment
abbylind Posted March 11, 2015 Report Share Posted March 11, 2015 Removed drive shaft, new u joints and carrier bearing, new diff pinion seal,new diff fluid, cleaned axle vent, new rear brake shoes, new brake hoses, adjusted and bled brakes and adjusted parking brake, changed tranny fluid, rotated tires, new center link, tie rod ends, idler arm, front shocks, Installed halogen headlights with daytime running lights, Installed GM rear view mirror with temp gauge and compass, Repainted front grille, New upper and lower radiator hoses and flushed system, New window felts and squeegees, New inside door handles, also added fatmat inside the doors. All this before 10 AM!...Ha!! Next is the interior remod...found the heater hose is leaking...drat! By the time I'm finished Id be better off removing the radiator cap and driving another truck under it! 2 Quote Link to comment
ownTer Posted March 11, 2015 Report Share Posted March 11, 2015 Removed drive shaft, new u joints and carrier bearing, new diff pinion seal,new diff fluid, cleaned axle vent, new rear brake shoes, new brake hoses, adjusted and bled brakes and adjusted parking brake, changed tranny fluid, rotated tires, new center link, tie rod ends, idler arm, front shocks, Installed halogen headlights with daytime running lights, Installed GM rear view mirror with temp gauge and compass, Repainted front grille, New upper and lower radiator hoses and flushed system, New window felts and squeegees, New inside door handles, also added fatmat inside the doors. All this before 10 AM!...Ha!! Next is the interior remod...found the heater hose is leaking...drat! By the time I'm finished Id be better off removing the radiator cap and driving another truck under it! You are getting shit done! 1 Quote Link to comment
