orangie Posted January 17, 2016 Report Share Posted January 17, 2016 Fluids filled up and ready to start or at least see if it turns over, no gas yet, but where did I put the key??? 2 Quote Link to comment
Clint1013 Posted January 18, 2016 Report Share Posted January 18, 2016 I swapped my bed with the good one from my parts truck. I learned it's heavier than I thought. Looks good, same color. 1 Quote Link to comment
red13 Posted January 18, 2016 Report Share Posted January 18, 2016 I swapped my bed with the good one from my parts truck. I learned it's heavier than I thought. Looks good, same color. Have any trouble with the tab bolts? 1 Quote Link to comment
red13 Posted February 20, 2016 Report Share Posted February 20, 2016 Found a mirror to swap in, with elevtrical dimmer 4 Quote Link to comment
Seeker > 620 KC Posted February 20, 2016 Report Share Posted February 20, 2016 Nice job on adapting it to orig mount? What did the new mirror come out of? Going yard picking soon 2 Quote Link to comment
red13 Posted February 20, 2016 Report Share Posted February 20, 2016 Nice job on adapting it to orig mount? What did the new mirror come out of? Going yard picking soon i browsedthe junkyard and found late 90s lexus ls400. The ball mount was basically the same, it was a smidge loose when,i swapped it in. So i wrapped the 620 ball,mount with a little bit of electrical tape to snug it. Plan is wire it in to the dome light power. 1 Quote Link to comment
red13 Posted February 20, 2016 Report Share Posted February 20, 2016 before I painted it, and mocked up the 620 mount 3 Quote Link to comment
HOGIE Posted February 20, 2016 Report Share Posted February 20, 2016 I swapped my bed with the good one from my parts truck. I learned it's heavier than I thought. Looks good, same color.What type of hardware did you use to reinstall your bed? I made these a while back when I swapped my bed. Haven't had to take it back off but I know it's going to be easier than with the stock bolts Finished my new bed bolts and mounted bed[url="http:// 4 Quote Link to comment
Rick-rat Posted February 21, 2016 Report Share Posted February 21, 2016 checked the valve adjustment, changed out cover, I couldn't believe how clean it was on the top of the head and the inside of the valve cover 3 Quote Link to comment
mhub91 Posted February 21, 2016 Report Share Posted February 21, 2016 rust issue on battery tray fixed 4 Quote Link to comment
mhub91 Posted February 21, 2016 Report Share Posted February 21, 2016 built roof rack installed BMW ellipsoids, built headlight harness and installed. all work, and OMG is there a difference!!!! 3 Quote Link to comment
red13 Posted February 23, 2016 Report Share Posted February 23, 2016 Decided to upgrade from a manual electric dim to an auto 3 Quote Link to comment
Rick-rat Posted February 23, 2016 Report Share Posted February 23, 2016 Started removing some of the rust on the body, tailgate and drivers side to the front fender done, lots more to do 1 Quote Link to comment
Seeker > 620 KC Posted February 24, 2016 Report Share Posted February 24, 2016 Who says you gotta be able to weld to do do sheet metal work? That's re-purposing at its finest! Wish I was that creative 2 Quote Link to comment
hosestop@msn.com Posted February 24, 2016 Report Share Posted February 24, 2016 This here 620 has flipped leafs no blocks and I am doing bodywork in orangie primer ,you can see how to re-arc in off topics,alleycat garage 3 Quote Link to comment
dueceduece11 Posted March 9, 2016 Report Share Posted March 9, 2016 Picked up a set of 720 4x4 springs 3 Quote Link to comment
abbylind Posted March 31, 2016 Report Share Posted March 31, 2016 Put an ad on CL looking for some BMW Z3 bucket seats.....2 hours later I was pulling out my bench seat and testing my new Z3 seats! 6 Quote Link to comment
Rick-rat Posted April 2, 2016 Report Share Posted April 2, 2016 L 20 motor. Got the intake, exhaust manifolds back on with all the bolts and all tight. 1 of the bolts with the thick washers was gone and 2 were loose and the hardest one to get to was just snug. got rid of all the EGR crap, was plugged and not working anyway. just waiting for my new carb to show up now 1 Quote Link to comment
orangie Posted April 3, 2016 Report Share Posted April 3, 2016 This here 620 has flipped leafs no blocks and I am doing bodywork in orangie primer ,you can see how to re-arc in off topics,alleycat garage I'm missing some of my primer. Quote Link to comment
Rick-rat Posted April 3, 2016 Report Share Posted April 3, 2016 Carb showed up late yesterday, did battle with the new one for a few hours today, I finally won. Now if I can fix that flat tire I'll be good to go 1 Quote Link to comment
dueceduece11 Posted April 6, 2016 Report Share Posted April 6, 2016 Before 720 4x4 springs After 720 4x4 springs 4 Quote Link to comment
Rick-rat Posted April 6, 2016 Report Share Posted April 6, 2016 Needs to be "moar lower" :thumbup: 1 Quote Link to comment
Rick-rat Posted April 7, 2016 Report Share Posted April 7, 2016 Did some half assed stuff today, piece of flex pipe to put the exhaust back together where I had to cut it to get the manifold off. Used some plumbers tape to secure the tailpipe, until I can get it welded up. Should be fine until after Lefty's meet, maybe even longer 2 Quote Link to comment
Jersey Posted April 13, 2016 Report Share Posted April 13, 2016 Steam cleaned the rear chassis and bed underside in preparation for the 4 link, step notch, and bags... 4 Quote Link to comment
DatsuNissanLove Posted April 13, 2016 Report Share Posted April 13, 2016 About to take the shock towers off n start cutting n grinding..n welding Quote Link to comment
