diff upgrade and 4link?
Dilligaf
  • Replies 10
That's like 1000 ft lbs, seems excessive. You will need a heavily built 9 inch or something of that nature.
Twin turbo V8 or something?
Keep in mind you will probably need a custom four link designed to resist that amount of torque at the wheels to keep from tearing the axle out of the truck.
Then a Hilux and the stock H-190 aren't even in the running, besides, no LSD.
Take a look at the WD22 Pathfinder. H-233 (that's larger than the legendary Ford 9") comes with 4 pinion LSD and 180 ft lbs break away on the early ones, 6 bolt so the 620 rims will fit, (well same bolt pattern) Had optional rear disc brakes and best of all is already 4 link coil spring and with panhard bar and a monster sway bar too.
