jimmy billy Posted July 7, 2014 Author Report Share Posted July 7, 2014 Ok and the other male end on the body is gound im guessing. Im tryin to put the matchbox in and i lined the motor to tdc and the diz is pointing to the #3 plug wire end......it doesnt want to go the right way i set it up for Quote Link to comment
datzenmike Posted July 7, 2014 Report Share Posted July 7, 2014 The male connector covered withinsulation on the far left goes to ground, yes. Does not matter where the rotor points as long as it's to one of the plug wire bases on the cap. This now becomes your #1 plug so move them all to get 1 3 4 2 and good to go. Quote Link to comment
jimmy billy Posted July 7, 2014 Author Report Share Posted July 7, 2014 Really??? Thats all it is? Holy shit! So it will be 1 3 4 2 counter clockwise?? Thats the way the rotor turns im sure. Quote Link to comment
banzai510(hainz) Posted July 7, 2014 Report Share Posted July 7, 2014 Dude look real close Mike already posted how to hook it up B is positive and C is minus side of the coil Oh dont be a dumbass and use the point coil unless you use the ballast resisitor also with it. If no ballast then get a 78/79 datsun/nissan coil(ex 200sx 620truck) I woul start up car with the old set up first just to make sure things work. You better get help before you fry the car up watch this all of it. Quote Link to comment
jimmy billy Posted July 7, 2014 Author Report Share Posted July 7, 2014 Good vid. Thank you. And im just making sure i got it right. So i dont fry my car. And when i can get cody to come check it out it will be finalized by him. Quote Link to comment
banzai510(hainz) Posted July 8, 2014 Report Share Posted July 8, 2014 lloks like you have a nice harness that isn't cut up. Why you pull it out? or this was a better one? Quote Link to comment
jimmy billy Posted July 8, 2014 Author Report Share Posted July 8, 2014 No the kid i got it from pulled it out along with half the other stuff in the car. Hes the type to pull the motor he unbolted every little peice and broke the motor down lol. Im just tryin to put it back together. If i did pull it apart id have an idea of how it goes Quote Link to comment
