5 speed trans
  • Replies 6
Wow, where to start...
1. reverse the crossmember for the front sump engine.
2. Dave Carrol trans mount.
3. Shorten the DL
4. add a walbro or MSD fuel pump.
5. custom radiator
6. put battery in trunk or run a really small one.
7. tons of little mods....
5 speed tranny out of a 280zx fit under my 521, should fit a 510 get the 81-83 non turbo 5speed better 5th gear. Then when you do the KA swap, you can use the 280 zx tranny as long as you put a NAP Z tranny belhousing on the 5speed.. At least thats the theory Ive gathered..
IH-'splain the Dave Carroll trnas mount please.
Its a custom mount made for installing any 5 speed in a 510. You can modify yours to make it work its just easier to use the Dave Carrol one.
is there a 5 speed trans that bolts in? :confused:the 1600 will do for now. :D
Yes there are 3 that bolt in with the stock driveline length....
1. Dogleg 79-81 200sx I believe
2. Nissan comp. tranny, good luck finding one
3. 1980 720 4x4 with the L motor also anther tuff one to find.
Yes but the DL will need to be shortened. Its only like 80 bucks. And the Dave Carrol bracket makes it easier.
does Dave have a site or place he sells them from?
I know Carter Boad has them as well...
Yep you have to contact Carter Boad, cool guy though :D
