retrorigg Posted July 3, 2014 Report Share Posted July 3, 2014 hi all im new here, ive recently purchased a 1983 910 (maxima) 1.8, im having major carb issues,its the nikki hitachi dch340 carb, when i go to rev the car its borking out, if i rev it manually by the second choke its fine, ive narrowed it down to the accelerator pump as i was barely getting a trickle when i worked the throttle, so ive fitted a new pump but the same thing happening....but if i disconnect the throttle mechanism and push the pump by hand im getting a nice jet of fuel, if i reconnect the throttle im back to a trickle, the pump is returning high enough to give it lift to pump fuel , im really stuck, any ideas please Quote Link to comment
ggzilla Posted July 3, 2014 Report Share Posted July 3, 2014 Nikki? Or Hitachi? What ya got? Quote Link to comment
retrorigg Posted July 3, 2014 Author Report Share Posted July 3, 2014 Wel it's a nikki but pretty much same as hitachi dch 340. Think its same layout accelerator pump wise Quote Link to comment
ggzilla Posted July 3, 2014 Report Share Posted July 3, 2014 A trickle is all that comes out of 1980s Hitachi. As long as it is a steady trickle its OK. If it starts and stops as you smoothly move the throttle that's bad. The Nikki needs a Nikki pump, the Hitachi pump is slightly different. Quote Link to comment
retrorigg Posted July 3, 2014 Author Report Share Posted July 3, 2014 What's the differences in the pumps. They both look identical side by side. It's not a steady trickle it's kinda hit n miss tricklewise Quote Link to comment
ggzilla Posted July 3, 2014 Report Share Posted July 3, 2014 Difference is about 1/2 millimeter Quote Link to comment
retrorigg Posted July 3, 2014 Author Report Share Posted July 3, 2014 Bore wise or height . Ya know under the little ball bearing that lays under the pump if I take this out is the jet underneath it removable and possibly blocked ??? Does the ball bearing stick or fail ? Quote Link to comment
