My 1978 B210GX *Supahachi
  • Replies 78
flippin' awesome.  Nice red color.  Is that the original black vinyl headliner?  If so, it will clean up great using a Mr. Clean Magic Eraser.  Mine is white vinyl and it was the best for cleaning the headliner.  Came out gleaming white.
One of the two biggest Datsun freaks i know has a b210 and even though he has big motor 510s jacked up 620s with dual Webers and what-not ,, the car he seems to always be driving,,,,,,,,,, THE B210
Problem with a"B"................Huh Nanner?
:thumbup:
I put a capital there but my auto correct must know the pecking order of Datsuns and changed it i guess.
I  do this :rofl: :rofl: because i'm picturing you flipping the screen off right now.
Good thing I took the van
10462801_530837900378199_537924922929829
Last night I went through the boxes for the first time.
Most the parts are new Nissan or used Nissan.
10525914_530837403711582_916192719042122
Water pump, three distributors, and a complete carb
Also some tools
10527754_530837450378244_810363305472163
NOS carb kit and some pluugs
10419509_530837470378242_849263069100228
It was as good as the best Christmas I've ever had.
Some more plugs  :frantics:  I guess I'm supposed to drive it till I di.
10367126_530838267044829_296456465922484
Nos air cleaner, gaskets, rv mirror, ignition module.
Someone tell me what the shifter is from?
10444556_530837557044900_464743453859164
10525987_530838233711499_148334872952038
10464300_530837640378225_818786088164879
10423660_530837537044902_181431584255505
Most the things I needed were in teh boxes. Such as this heater doohickey. Says rebuilt 94'. That's when the reman engine was installed.
10407173_530838293711493_383643380099587
10521343_530837707044885_629364529250843
Piles of seals, plastic bits, nuts and bolts, etc.
10488064_530837677044888_621988381834392
Shiny new fuel pump!
10478941_530838033711519_546039727298629
This is getting installed!
10346209_530838330378156_389176304686226
Perfect
10351668_530838127044843_377514897380869
10492295_530838377044818_332697479032365
10404530_530838097044846_510455874194908
Vacuum components. bulbs, sensors, switches, mos tthe dash knobs
1910635_530838453711477_4489072966585050
NOS tuneup tonight!
Plugs, caps, rotors, wires
Two complete starters
Antother box of knobs, switches, gas cap
10464388_530838400378149_370475931303755
Found guides and tensioners
10388184_530837597044896_359341821175977
This was what was all in the bottom box
Tail lights
10349949_530837947044861_844585188576340
More than a full set of NOS and used seals
About 50 lbs
66135_530838200378169_684146248416274118
Of course there is tons more!
