Maritime 510 - SR20/RHD swap
  • Replies 67
Looks good.
I noticed you painted them already....but are you going to swap your wipers over or leave them backwards?
I'll be leaving them backwards for now. Eventually I'll buy a Japanese or Australian wiper motor and convert it, but for now I'll just be leaving it as is so I can spend money on getting it running and driving first. I'll still be able to see when it's raining, just not as well. :P
I think it's just the linkage that's different?
I've been thinking about just making my own with rods and heim joints...    :rofl:
Do you have a RHD wiper cowl to get sprayed while the car is being done?
I thought the motor itself was different as well?, But as for the linkage, If my memory from research months ago is correct, I have to cut it and weld in an extention for it to work.
and as for a wiper cowl, that's something I'd have to pick up alongside a motor(if I do need a motor). I would of picked a cowl up sooner but wiper's just weren't a big deal to me at the time(which was a mistake haha). Otherwise I would of just moved the wipers over already and been done with it and have the cowl prepped for next weekend.
I'm not too worried though, I'm sure I'll have enough paint leftover to paint a new cowl in the future so the paint matchs well. Like I've said before, this is a budget-ish build haha, so there's bound to be some flaws for a while until I have money to correct everything.
and on a side note, if any of you guys noticed when I did my center-piece for the dash and moulded in a gauge pod, I finally painted it.... With black wrinkle paint!
and I must say it looks good, and looks like it'll suit the dash very well once I start pieceing that together too! I'll have to grab a picture of it. HIGHLY recommend that stuff.
It's mounted in the same location, so I can't see how it would be any different? I've always been told the linkage rods and wiper arms are slightly different and that's it.
130_0902_05_z%2B1971_datsun_bluebird_cou
Empirically, I can say I used the same Mazda wiper motor upgrade on my Bluebird Coupe with no issues.
Except now I really wish I had taken my wiper linkage out and made a copy or two...    :rofl:
Well crap,
This happened.
10661972_10205244457405543_3111298923409
10659407_10205240513226941_1553310819757
11043453_10205244457885555_5315530550397
10957588_10205244457925556_6447313113417
1617694_10205244457085535_10518901823869
10506978_10205244457045534_8953308604751
11063944_10205244458565572_5142271187237
11048662_10205244458005558_5669601845964
11016125_10205244458645574_1868329921202
11066516_10205244465005733_9557199199334
Took it to work at 10am, took it home at 5pm. I love bake cycles.
Spent the rest of the night cleaning up trim, painting random small things, and getting ready to reesemble for the most part.
I think my next big plan of attack is to tackle the heater and then wire it so I can get my dash together, and then do my interior!
Also will be tearing the rear apart soon to clean up/paint + replace my rearend with my subaru LSD.
Progress'll be quick now that it's painted. :P
  • Like 5
  • 3 weeks later...
So I got a few things in the mail!
11082575_10205364279601023_5258499773199
What isn't here, are my new shocks, electrical components, battery relocation kit, fuel pump, muffler, horn and a few other things. Needless to say I'm pumped because the car can go together that much faster!
However, the people I bought my rear windshield seal from messed up and sent me the front one, so I just had to order one express from Australia. oh well!
It's been a busy couple weeks.
me and my buddy ended up repainting my cheap new wheels(they're 15x7 + 25 offset so I can lower my car now at least), rotating my turbo, picking up the bits necessary to bolt it together, test fitting some stuff, cleaning up and polishing shiny bits, printing out wiring diagrams, starting to route brake lines, ran clutch line, cut + sowed up my rear seat, heater installed, tore out my rear subframe, cleaned up + painted/rockguarded underneath, tore steering wheel off(was going to replace but don't really got the time or money atm), and a lot of just small things I can't even remember.
10383573_10205337797538988_2908104889852
Here's the rearend out. I have to do a rear-disc conversion, but that won't be until next year probably.
The reason I tore the rear-end out was to be able to clean up + paint underneath, clean up + paint the rear subframe, replace the rearend with a subaru LSD, install lowering springs + new camaro shocks, cut the exhaust hole for my new exhaust and stuff.
Well, I'm not swapping out the rear for the subaru one yet because I don't have time to mess around with new axles stubs + changing the yolk so I'm just going to run the original datsun one for now. It'll give me time to save up for an R180 LSD anyway hahaha. Another problem was I forgot to unhook the brake lines and snapped them when the rear dropped(oops.)
I already got my shocks, and springs and I'm just waiting on getting my rear crossmember back with a 4 1/2 inch hole cut in it welded up with pipe inside of it so I can put my car back together.
The plan is to shove my interior back together, do my wiring, get some tires mounted on my wheels, put my doors back together(since I just got my new doorhandles :D), put the windshield + rear windshield in(once my new seal comes in the mail...), cut up + weld my intercooler piping, find some 3" mandrel bends and some exhaust piping so I can weld my exhaust up(since I also got my muffler :D), run my fuel lines + pump + fuel cell, vacuum lines, modify my seats to fit, rig up a center console, and a few other things. Going to throw a buff in there too!
Kicker is I'm doing most of this in the next 15 days due to a car show coming up. Even if its not together, It'll look like it's together hahaha
That paint looks great. I wouldn't change a thing, but if you ever wanna paint the hood flat black, just pull off that hood and paint a different hood flat black. That way you can swap back and forth any time you like and have all the matching paint. :thumbup:
So as I have a car show in FOUR days. me and my buddy have been working steady on getting our cars done/ready enough.
Progress in the past few days would include, Turbo mounted, Intake made and fitted installed and taken back off, turbo lines ran, downpipe installed, catch can figured out, what I need blocked off figured out, Merging the SR20 harness with the 510 harness, speakers + stereo bought so I can fill a few holes, lowered the car, brake lines all ran + bled, clutch bled, battery relocation kit + switch, trunk cut to house the fuel cell, holes cut for fuel line, fuel line halfly intalled(waiting on a few fittings), doorglass installed(would have doors together completely but the new doorhandles are having a slight fitment issue), cleaned up + repainted door covers + rear side covers, pan made for where the transmission tunnel was cut for the SR20 transmission, routed other wiring, and too much stuff to remember.
During this process, I have figured out I needed quite a bit of odds and ends and hopefully they get here in time. I'm currently waiting on rear windshield seal from datsport, O2 sensor adapter, rad hoses(why no speed shops around here stock the little stuff still stumps me), and some AN fitting adapters.
Also found out today I need to grind some off the tie-rod ends and add 3mm spacers as when we were moving the car they decided they wanted to dig into the wheels which made a nice groove and pushing a little bit difficult haha. little things though, right?
The buddy that's helping me with the 510 owns the subaru in the pictures and we figured we misawell get the cars together in the same garage so we don't waste time getting our cars together for speed sport on thursday. after a few hours, his car's basically already ready to go so for the next few days after work we're both going nonstop on my car(minus buffing and a downpipe gasket for his haha).
The plan of attack for the 510 next is to finish up the wiring completely(which won't be hard as it's basically just gauges, ECU, fan and checking it over left). then sand + buff both cars, finish up the intercooler piping which I started, finish up the exhaust, seal off a few vacuum lines, install catch can, run the rest of the vacuum lines, finish off the fuel lines, install the radiator, PUT IN THE WINDSHIELD + REAR WINDSHIELD, door stuff, modify the seats + install them, lay the rest of the carpet, finish up putting the dash together, change the oil, run coolant in it, and whatever other surprises pop up.
I know it probably won't be running for thursday but it'd be sweet if it was. Good thing we have a trailer now :P.
and here's some pics.
11054527_10205376429064752_3608615992931
15819_10205376429584765_2696804465902976
11136164_10205446348972706_4633741992700
11088495_10205446349012707_5194112596972
11062744_10205446349452718_2285915989222
11136193_10205446349492719_3151041195289
11039056_10205446349932730_7198603896054
1484038_10205446349972731_24471945674968
905635_10205446350452743_233691441350631
11061973_10205446350012732_8699544006264
It doesn't really look that nice atm, but once it's more near completion, it'll look a lot cleaner and more together. Most of the stuff is just halfly put on currently as it's just going to come back off to reinstall other parts or checking to modify.
Oh well, Progress right?!
  • Like 3
Well, I ended up taking the car to a car show.
...but on a trailer.
It's just about to run though! Just kinda ran out of time.. I just need my fittings to hurry up and come in the mail so I can actually piece it back together. The only things it needs(unless something goes terribly wrong..), are the fuel fittings, one coolant fitting, rad hoses(which came in today), o2 sensor adapter(which came in today, and to finish up a few grounds, one ignition wire and all my vacuum lines.
...also wait on turbo flanges so I can finish up my intercooler piping.
The other bit is once it's running is to nicely tuck/wrap the wires so it looks more appealing under the hood(bit of a mess currently).
but here's a bit of a teaser of the car currently.
I have motor shots and more photos, just aren't uploaded from the camera yet.
11174958_1588202474792166_42135951118438
10624941_1588202504792163_87832401421910
11169900_1588202451458835_40609090610673
Due to work (and the woman), I won't be able to work on this for the next week, but I plan on it being drivable by the end of the month.
  • 1 month later...
Well it's been a while since I last updated. so here I go.
Spent hours, upon hours going over the wiring, after trying to get it going, and troubleshooting why it wouldnt.
Turns out one big problem is that all four of my coilpacks were cracked. I'm currently waiting on new ones to arrive so I can knock that off the list (and hopefully it'll run.)
Car is currently a mess as the dash is torn all apart with wires going everywhere from the troubleshooting :P.
It was quite the ordeal though, bouncing between no spark and no injector pulse. Going through the harness though, it was easy to spot forgotten little gremlins(like unhooked grounds... Oops.)
I checked the igniter chip, the CAS, and everything else I could dig up on the internet to go over. so here's to hoping it's just the fact the coilpacks are coated in cracks is why it wouldn't go.
Other then that though, the car is buttoned up! ...Mostly
 Fuel lines are ran with no leaks (anymore), all my vacuum lines are ran, all the wiring neccessary for it to run is wired up, etc etc.
Once the car's running though, I'm going to tidy everything up as wires are everywhere open, and install the new modified fiero rad so the rad hoses can be installed along with filling it with coolant and putting that slim electric fan on!
The only wiring that needs to be finished is hooking up the tach, and running a couple wires for the temp gauge, oil gauges, and ground the fuel.
So basically I've been watching the tracker for my coilpacks nonstop hoping they'll arrive here sooner.
It felt good to actually change the oil, and start doing a few maintancy things to it though. Getting excited to hear this thing go!, espicially with the homemade exhaust haha.
Anyways, here's some photos!
11258727_1594044597520773_1731833675_n.j
My poor stock coils :(
And a few more from speed sport east.
10535573_10205733315666694_5759344876809
11070147_10205733315706695_3243219953194
11118607_10205733315946701_6211304729132
..I'll be getting new wheels eventually, just hard to find stuff here locally :P
Well, we got it running, and all legal and managed to take it out for two drives!
It just sucks because it broke down for the car show which happened to be the next day.
Fuel pump decided to break down on us at 11:30pm the day before the car show and had to get a tow haha.
Anyways, my buddy and I (who has a build thread on here), decided to go out and get some pictures (before his car also broke down after his like 300km drive to where I live),
11406336_10153280109971208_4646334501092
11411737_10153543623809305_7982299545000
11312734_10153280277926208_3014971479969
11126913_10153280278281208_3502362693249
11110991_10153280278461208_2594587167334
10603799_10205839004708854_6320183472657
From driving the car, a few issues were found, and a lot of them fixed.
They would include working tach, exhaust being too low and hitting off EVERYTHING, passenger side panel, fuel pump, oil temp gauge, ignition switch, and a few other things. Most of which were fixed. Unfortanately the fuel pump and exhaust haven't been fixed yet.
The plan is to get a new fuel pump and hopefully get on the road again.
Thankfully though, we fixed my buddys 510 as it was just the altenator loose and he needed a new battery as it draining so much ruined his.
I've put maybe 40km on this, and it's working amazing for the most part. it goes like snot even just giving it a little bit of gas which is promising haha
  • Like 3
  • 2 months later...
Well it's been a while since I did an update.
I've been driving the hell out of this car, and taken it for a lot of cruises and bunch of car shows which has been great because it's quite a blast to drive, espicially with my trusted puppy beside me.
The other day I even ended up blowing up the stocker R160, and currently running into difficulties with a subaru LSD. The car has had quite a few bugs worked out of it already though such as the front tie rods and RHD center-link, so that's a plus. Just need to get some bigger brakes, coilovers for more low, front sway bar and it should be a dream to drive.
Text is boring so here's some photos collected up over since my last update.
11380160_1431585400497532_1163205160_n.j
11326821_853289624765121_1554586177_n.jp
1610803_10205924921816728_73703145929538
11536109_10205965400428668_2829949998614
1390143_1461260874174934_1432756982_n.jp
11375189_1632234403684810_1931901372_n.j
11247888_10206094756262483_6051271299583
11356779_1617301335221419_804842417_n.jp
I talked my dad into going out with me for a cruise to a local meet with his shoebox!
11225167_10206032077535554_3400283406117
11709549_10206032996478527_8594776422874
11751476_10206120100736079_1453852911430
11728750_925346664170822_807048150211900
11705147_955406677831160_743463230852831
887575_1695932923961388_5431723613952868
11822620_10206237038179442_3059526372073
11846500_10156068231880413_5890832640329
11781833_10206233142122043_8742314851679
Hopefully sticking in a R160 open rear end tonight from my friend so the car can still be driveable until I can either get my R160 subaru LSD rear to work, or I manage to pick up an R180 LSD. I was going to tear the rearend out of my 260z for this, but found out that all 2+2's had R200s :(
Just sucks that the first time I ever put it to the floor, it decided to blow up in second gear lol.
Since this is driveable now(minus rearend situation atm), I decided to start working on the ol' prostreet cavalier again too!
Also debating on selling my factory 510 tach, couple THICK front swaybars, and a few other oddities of 510 parts since I have no use for them.
  • 1 month later...
Well, it's been a while since I last posted so here's an update.
I had to shove another stock datsun R160 back in the car just so I can drive it(at least I can drive it :P), and ended up going on a few long cruises and a couple shows.
Still on the hunt for a decent R180.
One of the cruises I went on, involved a couple other local 510s.
11870638_10206348238839389_5905100620443
11899913_10206348238679385_1476689803124
11817202_10206281381047986_5926335982163
10435661_10206281381367994_8310301546460
11910239_387980824745243_2057585117_n.jp
As winter is approaching and the car'll be taken off the road for it, I think I'm going to hold off on working on it until after it's put in the garage for good.
from driving it this year, it's obvious this winter it'll be getting front coilovers + 280zx brakes, rear discs, front sr20 sway bar and an oil cooler kit.
The turbo seals are starting to get a little bad too, so I'm going to have to pick up a T28 before spring.
  • 4 months later...
I'm just going to copy and paste my post from therealm as it's getting late at night and I work quite early.
I guess it's been a while since I did an update haha,
well, since august a lot has happened, so I'll try and post what I remember haha.
I managed to score a 2013 subaru R180 Torsen LSD through work for $300 Canadian(basically $100 for you Americans now haha), wit only 20k on it. The downfall is it's only 3:54's gears right now but we'll see how it drives and I may keep them, or upgrade to some 3:90s or 4:11s.
Incase you guys don't remember, the whole reason I needed to upgrade to the R180 was because of this...
12394042_771740456302781_1570926217_n.jp
So since it's the winter months, I also decided to tear the turbo and stuff off since I was having a few issues. The turbo was burning a little bit of oil, the exhaust was leaking, and just a few other small issues.
Turns out the oil issue was just having the wrong oil restrictor on it(or basically lack there of haha)
but everything went back together fine and just waiting on my next bit of work on the car, so I can get it to run and make sure everything's fine.
Since the 510 was getting more reliable, I decided to bite the bullet and buy an oil cooler so my temp doesn't keep climbing during highway driving.
I bought a universal mishimoto kit with a thermastatic sandwich plate.
They ended up forgetting to send me a fitting with the kit, so I had to order a new one, and since I was at it I decided I'd use a oil relocation kit I've had stored away forever so I ordered a few more fittings and hoses through work.(I'm still waiting on the actual fitting for the sandwich plate though as it's on backorder haha).
I ended up having to modify my motor mount as the sandwich plate didn't want to clear too well.
10616382_967073656697537_2124344211_n.jp
Also decided on ordering a wideband as I purchased a Nistune ECU a while back and finally going to put it to good use and get some tuning done.
Here's a picture from since my last post. After taking this photo and getting back on the road, a deer jumped out in front of me after I got back up to highway speeds. FUN FUN FUN.
11899568_1196778050348997_1097536931_n.j
One reason I haven't really been updating on the forums too much is because I've been too busy working and trying to decide what to do with my other project.
The reason I'm trying to decide what to do is because the motor decided it wanted to overheat and cook itself when I was driving it to put it in storage.
10853047_187202228289826_1951870790_n.jp
11248191_920221594692777_1935167607_n.jp
Incase you're wondering what it is.
It's a pro-street 1982 Cavalier(well Clone.. It's a Firenza shell) hatchback, converted to rear wheel drive with a V8(sbc).
I've been wanting to sell it so I can buy a '55 chev, but noone would ever give me anything for it as a rolling chassis. I've even had it posted haha.
So the plan now I guess if it really doesn't sell, is to shove a 5.3 LS I bought off my coworker into it, with a turbo kit.
It's kind of hard bouncing back between two projects like this haha.
But here's some more photos I've forgot to post incase anyone enjoys!
12142674_1649830568632172_1033401102_n.j
11809936_1468737810102091_1120443518_n.j
My datsun with my dad's '55 hardtop.
11917919_1445135319150681_504136286_n.jp
11248989_444169959089512_1792209148_n.jp
11939493_191134447893290_1448706412_n.jp
The more pictures there are, the less boring it is, right? hahaah
  • 3 months later...
Been a little while since my last post :P
Biggest things to say are...
THE SNOW IS GONE!(and the salt).. I've actually had the car out for a few rips! Including taking it to one of the biggest car shows in the maritimes.
It was the first of the season, and I went with a group of buddies under the name of Maritime RHD.
I finally bought T3 front 280zx coilovers. I also traded my dogleg 5speed for another pair of 280zx front struts that were suposs to be complete, but lacked one caliper bracket, and both calipers. However, they did include hubs so that's the main thing. I'm trying to find a place to buy all new rotors, brake pads, calipers, wheel bearings, and balljoints but so far no luck, even through work haha. Probably just going to buy a 'big brake kit' and say screw it.
I've also made the homemade rear coilovers at work because I was bored(camaro shocks, honda civic coilover kit, etc etc), but think I'm going to just buy proper coilovers because the car tends to want to squat too much and scrape a little too much for my liking while accelerating.
I also flocked my dash! and do I ever love it. It feels just like my dog so it was nice rubbing it when I was away at speedsport for four days with it haha.
Another thing I'm really proud of, is I finally managed to find brand new door locks for the car. Now I just need a trunk lock lol.
It feels really good to be able to play with the car, without worrying too much about breaking the rearend anymore.. Hell, my gas milage isn't half bad either hahaha.
One thing about my recent trip to speedsport though, is I was suposs to do an alignment at work but that got way too busy, so I ended up driving the few hours there with my car decently out. arrived with almost bald front tires.
When they were handing out awards, me and my buddy did a string alignment(with two jackstands, some speaker wire, our weekend pass and a marker) to do the front alignment after figuring out the front and rear track widths were the same.  Rotated my tires so it looked like a burnout machine, and made it home fine with no more wear.
Anyways, here's some pictures !
12748455_1725994270948362_1600760700_n.j
Painted up my old scratched, fading cam cover. Roulette green!
12912666_1765019483719528_189416081_n.jp
12965024_1533079526997914_1098009114_n.j
Speedsport_23.jpg?resize=1024%2C683
Speedsport_21.jpg?resize=1024%2C683
13043534_10207996307440074_4914627462934
I even brought home an ISCA award for rising star!, and first place for my class.
13041071_10207996270599153_7614203627295
Twiggy was also at the show so figured I misawell go see her haha.
13041359_10207989071998516_8268511844895
So just to recap because I'm rambling, the plans now are to buy everything for my struts so I can finally put my 280zx struts/coilovers on the front, buy rear discs, buy new wheels, buy a T28 turbo, hook up my nistune and tune it, install an E-brake (lol), and just enjoy the car. I'm hoping to start autocrossing it this year as well.
I'm going to Montreal next month with my buddy to go to all the JDM importer shops, so I'm hoping to be able to pick up some unique goodies, or upgrades (really hoping for wheels lol), so I'll post if I get anything!
