COOCHaDAMus Posted June 28, 2014 Report Share Posted June 28, 2014 i changed out my fuel delivery awhile ago from stock hitachi carb to dual weber side drafts. i blocked off my return line back to gas tank. is that line even needed or not? i haven't had anything go wrong runs like a peach just curious. Quote Link to comment
ggzilla Posted June 28, 2014 Report Share Posted June 28, 2014 No carb needs the fuel line. * be sure the vent line is not blocked * some carbs will overflow without a return line This indicates that either the fuel.pressure is out of spec, or that the carb's inlet needle & seat needs replacement. Hitachis are rated for 3.8 psi, Weber's for 3.5 psi, but both usually work OK at up to 5 psi. 1 Quote Link to comment
MicroMachinery Posted June 28, 2014 Report Share Posted June 28, 2014 I'd use it. If nothing else, it keeps the fuel cool and prevents vapor lock. 3 Quote Link to comment
COOCHaDAMus Posted June 28, 2014 Author Report Share Posted June 28, 2014 thank you's GGzilla & MicroMachinery for your teachings of the forc.............naw i'm not gonna say it. Quote Link to comment
datzenmike Posted June 28, 2014 Report Share Posted June 28, 2014 The return line is strong with this one. Quote Link to comment
DanielC Posted June 29, 2014 Report Share Posted June 29, 2014 If it really was not needed, Nissan would not have put it there in the first place. Quote Link to comment
ggzilla Posted June 29, 2014 Report Share Posted June 29, 2014 Same for EGR, spark delay, etc. If the 510 didn't really need spark retard, Nissan would not have put it there. Or - could it be: When something has a purpose, a usefulness, it doesn't mean it is required? Quote Link to comment
