alextremo Posted June 25, 2014 Report Share Posted June 25, 2014 The rear axle on the passenger side 'blew out' while i was driving. started leaking gear oil. seems like the bearings are broken. how do i know if i can just replace the bearings or need to replace the entire rear axle. I am thinking about repacking it...what are my options.. ? pics coming.. thanks in advance Quote Link to comment
ggzilla Posted June 25, 2014 Report Share Posted June 25, 2014 how do i know if i can just replace the bearings It makes a terrible horrible noise if the bearing has broken Quote Link to comment
ggzilla Posted June 25, 2014 Report Share Posted June 25, 2014 The rear axle on the passenger side 'blew out' while i was driving. started leaking gear oil. Replace the seal and repack the bearing. Quote Link to comment
alextremo Posted June 25, 2014 Author Report Share Posted June 25, 2014 ok. doing that. what else should i check for replacement as long as i'm down there...? thanks Quote Link to comment
ggzilla Posted June 26, 2014 Report Share Posted June 26, 2014 Nothing. Those are the things that need normal maintenance. Also make sure the rear end is topped up with lube oil. Quote Link to comment
