...datlife......always Bustin' Nuts......
 was motor apart then reinstalled and not running since then
History would help
I'll leave this here........
This just showed up at the shop....from Washington.......for me to put back on the road for a dude in SoCal...
I know this car......who's was it and what happened??
I haven't even opened the hood yet.....
OK so I bought this car with the intentions of getting it back on the road. I sold it to hooligan after I did absolutely nothing to it. He could not get it running to save his life and I don't know why.
I bought it from a guy who got it from the original owner, little old lady that bought in new in wyoming in 73 and brought it to Washington in 85. Car died in I want to say 87 or maybe 92 and just sat until I got it. Has an L18 and a 4 speed.
.....so it hasn't run since about 92??
It was something like that. The guy I bought it from pulled the valve cover off and oiled the cam and timing chain, then he used a brake evacuator on the fuel system, then he found out the starter was bad. Thats when I bought it. Hooligan put on a new carb and an ei dizzy and did a bunch of other stuff and could never get it to run.
Much like my ex it had a couple dead holes. Last I remember he had low compression in a couple cyl.
http://community.ratsun.net/topic/62110-what-am-i-overlooking/
  • Replies 1.4k
Just noticed this thread, you sir are a Datsun Savior. :)
Wish I could find a four door in the woods like that butterscotch.
Thx man......I do what's in my power......
Did you try trans fluid in cyls. to loosen up ! maybe rust is the culprit .
Don't think it's that king of issue......it starts to spin and hits something.....not a gradual stop....
I doubt transwould be in gear. he works on cars for a living........... ????????????
a guy told me that was hardcore into Datsun for years.
He said he made new motor mounts for a L20 in his 521 So oil pan wouldnt hit. I said, Use a 521 oil pan done.
Then he said He dropped the oil pump and turned it 180 to line up the rotor to get it running. I said , just move the spark plug wires 180 degress. But like you said he works on cars.
Shit even I done it.
Built my 1st motor and it didnt spin around either. I ripped the head off checking out everything. then find out I had a flywheel bolt sticking out far enough to hit the engine tand plate in back. that why it locked up.Crap Waisted a nissan head gasket
just checking we all make simple mistakes sometimes.
If this car was towed home then I would most likely loosen the crank bolt and cam sprocket and pop the head and front cover off and least put a new tensioner in there and slack side guide in there.
maybe pull the oil pump 1st in case the spindal jammed up for soem never heard before reason
Interesting that the oil gallery has already been tapped and plugged. Better remove the plugs and flush the shit out of it. That (among other things) feeds directly down to the crank mains.
I was unaware of this......will do....thx Mike...
OK......
Goals for this week.......let me know if all this is possible.......
-Finish diagnosing 610......
-Finish putting 2.2 together to drop into my car....
-Complete rebuild of Kalani's engine....
-Complete front suspension rebuild on Kalani's Dime.....
-Rip engine out of Loogie because I need the clutch and flywheel for 2.2......
-Put my car together and have on the road by Monday.....
-Get Kalani's engine and suspension in......minor mechanics and cosmetics to get it running by Dec. 1...........
:w00t:
Anyone got some NZT-48????
  • Like 3
OK......
:w00t:
Sounds like you won't be sleeping
  • Busta Nut changed the title to ...datlife......always Bustin' Nuts......
