what oil pan can i use on my 521?
vodkanmilk
Hello Ratsun freaks!
i have a 1972 521 datsun pick up for some odd reason my center link hits on my oil pan.
iv been reading on the forums that i might have l20b oil pan is the reason it hits.
also was readin that a l16 oil pan might do the trick.
but any advise would be great!!!
  • Replies 19
Only the L16 pan from a 521 will work for sure. The pan from an early 620 may work.
You mean the steering cross rod? Check that the idler arm bushing isn't worn and allowing too much up and down movement.
If there is a well marked rub spot drop the linkage down or turn fully to one side and using a ball peen hammer dent the pan in to clear.
Welcome :)
I have a question, did you do the engine conversion to an L20B?
Were you even able to get the centerlink connected, is the centerlink bent?
  • 3 weeks later...
This may be old news but I had a similar problem when I got my 521.  I found that the motor mounts were the problem.  The engine had dropped and was causing all kinds of vibration.  I found the motor mounts at Pep Boys.  I checked everywhere for them.  Still looking for a new transmission mount.  Huge difference in the engine noise and clearance of the rod.
