Datsun Metal Shaping - Automotive Panel Craft
Thought we might start this thread for those interested in metal shaping.
We will kick this thread off with a Full Rear Quarter Panel for a Datsun Roadster. This is the panel that was needed to be replicated.
dfd558c5caa33d5639fead2951f8815b_zps3023
Work began by taking a template from a Datsun Roadster then marking it out on the steel. (1mm cold rolled mild steel)
Cutting with nibbler and roughly trimming panel to size.
6ce160debbad533ad6cce0d1b7f4bd42_zps9384
5952c7a61b619592aa1aaa6619fd02a1_zpsca18
More to come
  • Like 5
  • Replies 42
This is a picture of it cut out and ready to start work on the english wheel.
7316e6af424524b096580aa1e6823fd1_zpsc1dd
After several hours of intense shaping in the english wheel, our flat piece of steel has started to take shape and is matched up against the original. This happens several times during the English Wheel process.
2c7afceda354f4bf33e69457eb3c68e0_zps0bbb
f9fbff9df053a2a736c519c7c0a2a5f7_zps496a
After the English Wheeling is done, its time to start on the wheel arch.
The Wheel Arch is beaten out with a blocking hammer.
7eecfa811c5ff9d8e7c7d7762b3d4942_zps0586
Wheel Arch has been shrunken down then run through the bead roller to sharpen up the edge.
It also goes through the shrinker to pull the flange back down.
7dc57b5eb189797951540c398a110120_zpsb29a
  • Like 4
If you ever want to see if something is truely straight, symmetrical or identical try turning your back and viewing it through a mirror, its like a new set of eyeballs. An old sculptor taught me this trick and now can't live without it.
  • Like 3
  • 3 weeks later...
 After shrinking down the wheel arch its time to clean up with a bit of planishing.
Now we shape the return under the Rear Quarter.
Completed and on the car and ready to paint.
Now it has been painted.
Its ready to be sent to the customer.
Next update will be the customer installing the panel and the final finish.
  • Like 4
Time for the customer to install. Rear Quarter is removed and ready for the new panel to be welded on.
0fd298807af71c6e78c642fbf155754c_zps4768
f0fadf7090088c2a5ebccdd56b950be9_zps03fa
Customer has the panel in place and welded on.
b2316c8de27ddbfc39b9a4e86e192525_zps5a12
8c93c6c2671da8bcad55cd48aac28a8d_zps0661
5d2d85626ee8b3df24f0134ff8cb47c5_zps1661
The rust repair has been completed. Time to paint and finish off the restoration.
6962954c3a9d5b6d36bd12cde521e3d1_zps2922
Here's the car as it started out.
And now here's the picture of it fully restored to its former glory.
20140609_131117_resized_1_zps726f7dd2.jp
fairladyroadstercustomerscar_zps08d671f8
Thanks for following this restoration. Leave us your thoughts and tell us what other Datsun's you'd like to see the metal shaping on.
  • Like 8
