Scgreen620 Posted June 11, 2014 Report Share Posted June 11, 2014 Where do you guys buy your sound dampening material that's bang for your buck? Quote Link to comment
datzenmike Posted June 11, 2014 Report Share Posted June 11, 2014 Roll on roofing tar also known as 'torch on'. Roofing companies throw away end pieces because they want to avoid joints. I got all mine for free and even a whole roll. Its dry (not at all sticky) rolls out and easily, about 3/16" thick and 36" wide, cuts very easily with tin snips to odd shapes, can be heated to soften with a propane torch and pushed into dips and corners and even joined together. One side has a plastic skin on it. Did both my 710 floors with it including under the back seat. Fuck that overpriced crap with the foil on it. 1 Quote Link to comment
67_1600 Posted June 11, 2014 Report Share Posted June 11, 2014 Home depot I'm not sure which product you used, but this is the stuff I used from Home Depot. It doesn't have an odor like a lot of the other roofing products. According to their website, it's $16.45 a roll. 2 Quote Link to comment
Colbino Posted June 11, 2014 Report Share Posted June 11, 2014 I went with Raaamat - http://www.raamaudio.com/ Check'em out! Quote Link to comment
Just Joel Posted June 11, 2014 Report Share Posted June 11, 2014 I'm not sure which product you used, but this is the stuff I used from Home Depot. It doesn't have an odor like a lot of the other roofing products. According to their website, it's $16.45 a roll. Yep... 1 Quote Link to comment
Scgreen620 Posted June 12, 2014 Author Report Share Posted June 12, 2014 Have you physically installed this your self? Quote Link to comment
Just Joel Posted June 12, 2014 Report Share Posted June 12, 2014 Two vehicles... works perfectly, no smell. I have experience with this product and the more expensive name brand products. Quote Link to comment
Scgreen620 Posted June 26, 2014 Author Report Share Posted June 26, 2014 Okay I applied the material works amazing ! No smell... It does work ! Quote Link to comment
JoeCool Posted June 26, 2014 Report Share Posted June 26, 2014 I am going to have to try that in my truck on the floor, rear cab wall, and firewall. Quote Link to comment
Scgreen620 Posted July 16, 2014 Author Report Share Posted July 16, 2014 I only put some 1/4 of the way and I can tell the difference Maybe 4 rolls and your set Quote Link to comment
Just Joel Posted August 4, 2014 Report Share Posted August 4, 2014 Very nice ;) Quote Link to comment
MantisX620 Posted October 10, 2014 Report Share Posted October 10, 2014 Would you guys recommend just putting the U seal down and carpet over it, or U.Seal, Jute padding, and then carpet? Quote Link to comment
67_1600 Posted October 10, 2014 Report Share Posted October 10, 2014 Would you guys recommend just putting the U seal down and carpet over it, or U.Seal, Jute padding, and then carpet? Padding will deaden/muffle things even more - I'd use it if you can. 1 Quote Link to comment
Scgreen620 Posted October 15, 2014 Author Report Share Posted October 15, 2014 Would you guys recommend just putting the U seal down and carpet over it, or U.Seal, Jute padding, and then carpet? I've heard the jute they use on houses is better than the one for cars check it out I might be wrong ... Quote Link to comment
MantisX620 Posted October 17, 2014 Report Share Posted October 17, 2014 I picked up some Jute from home depot that they use on home carpet. Will let you guys know how my cab noise is once everything is back together. For carpet, I got it out of a 94 S-10 in the junkyard. Damn near direct fit. Quote Link to comment
Scgreen620 Posted October 19, 2014 Author Report Share Posted October 19, 2014 Nice! Let me know about heat too my floor gets hot because the muffler runs under the seat Quote Link to comment
datsunon22s Posted October 19, 2014 Report Share Posted October 19, 2014 dynamat. and u guyz go cheap as fuk wit home depot shit go well wit walmart limp dik bass Quote Link to comment
datzenmike Posted October 19, 2014 Report Share Posted October 19, 2014 We had this conversation before... speak English when insulting people or they might not get mad. Dynamat is over priced roll on roofing with aluminum foil on the back. You can get the same results for free. 5 Quote Link to comment
Son_of_a_Datsun_Guy Posted October 20, 2014 Report Share Posted October 20, 2014 I'm doing a combination of heat treating similar materials to Datzenmike and then I'm using carpet padding/jute. I got my jute from miamicorp.com. Its pretty cheap and is working well so far. Quote Link to comment
Scgreen620 Posted October 22, 2014 Author Report Share Posted October 22, 2014 dynamat. and u guyz go cheap as fuk wit home depot shit go well wit walmart limp dik bass Not every one wants to pay more for the same thing 1 Quote Link to comment
wayno Posted October 22, 2014 Report Share Posted October 22, 2014 The Home Depot shit works fine, I used it in the doors on the 521 kingcab, made a big difference, and it was only $17.00 a roll, it sticks to everything, even stuff you don't want it to stick to, been there for a couple years now, I only used half the roll. :) It's kinda hard to understand the new guy, it's easier to ignore him than to try and read his reply. 1 Quote Link to comment
datzenmike Posted October 22, 2014 Report Share Posted October 22, 2014 Yeah we don't feed the trolls around here. Quote Link to comment
Swedishcadillac Posted October 22, 2014 Report Share Posted October 22, 2014 I'm gonna try 3m flashing tape from amazon... Quote Link to comment
