Justin Berni Posted June 10, 2014 Report Share Posted June 10, 2014 So I lowered my 720 a while ago, and at one point I had the torsion bars maxed out and I had a noticeable amount of negative camber, I didn't want camber wear so I raised it up just enough to not have any negative camber, or atleast none that I could see. But now I wanna go lower without drop spindles, so my question is can I max the t bars out and correct that negative camber in some way? I know for a lot of cars there is camber kits but I can't find anything, and I've already searched the forum. Quote Link to comment
]2eDeYe Posted June 10, 2014 Report Share Posted June 10, 2014 You should be able to use shims to move the top of the tire in for more camber. You can remove shims for less camber. If you removed all the shims and still want less camber you will need custom a-arms. Stock camber on the 620 is 1 deg. Quote Link to comment
izzo Posted June 10, 2014 Report Share Posted June 10, 2014 Here's the deal... Up until 1983 the upper A-arms are mounted on the inside, like the picture above. 83 and later they are mounted on the outside. So, since you have an 86... the tops of the tires are sitting to far in. A couple cheap washers from the hardware store will work perfect to space that thing out. You will probably need 4, stacked in a pair of 2 on each side to push it out. That should be close. Maybe get 6 just in case. (per each side, so really get 12 washers. they are cheap, should be under 5 bucks). The pre 83 rigs are awesome to be raised. As when you raise them, you get positive camber.. Since the A-arms are on the inside, it's easy corrected. Not so much on the 83 and newer rigs. Same goes for the opposite, tho. 83 and newer are easier to lower and slam out since the upper a-arm sits on the outside of the frame rail... Just add shims, and done. Doesn't require fabbing, replacing A-arms etc. 2 Quote Link to comment
ggzilla Posted June 10, 2014 Report Share Posted June 10, 2014 Yes, you don't need a camber kit because unlike Datsun cars, the trucks are adjustable in the traditional way (with alignment shims). Quote Link to comment
ggzilla Posted June 10, 2014 Report Share Posted June 10, 2014 What makes it easier than the few washers needed for the 1986? Since the A-arms are on the inside, it's easy corrected. Not so much on the 83 and newer rigs. Quote Link to comment
Justin Berni Posted June 11, 2014 Author Report Share Posted June 11, 2014 Where exactly do the washers go?? Quote Link to comment
datzenmike Posted June 11, 2014 Report Share Posted June 11, 2014 Tim I have the '84 FSM and it shows them all on the inside just like the earlier 620s. Quote Link to comment
]2eDeYe Posted June 11, 2014 Report Share Posted June 11, 2014 Where exactly do the washers go?? They go between the a-arm cross bar and the frame mount, with the mounting bolts going through the a-arm cross bar then through the washers and finally threaded into the mount. Quote Link to comment
Justin Berni Posted June 11, 2014 Author Report Share Posted June 11, 2014 Alright, I think I can figure this out now, thanks for the help! Quote Link to comment
