sammym Posted May 14, 2014 Report Share Posted May 14, 2014 Does anyone have any installation tips... I have the parts and have not started yet. Thanks, Sammy Quote Link to comment
hobospyder Posted May 15, 2014 Report Share Posted May 15, 2014 I'd say do channels first and then the squeegees but I haven't done this particular project yet. Parts are in the garage, just being lazy Quote Link to comment
datzenmike Posted May 15, 2014 Report Share Posted May 15, 2014 I tried contact cement on the channels... didn't work for me. They slowly work their way down with the window. The squeegees just clip in. Take your time. Quote Link to comment
]2eDeYe Posted May 15, 2014 Report Share Posted May 15, 2014 I used the right stuff instead of contact cement on saggy channel felt with good results. Quote Link to comment
Digger48 Posted May 19, 2014 Report Share Posted May 19, 2014 Sorry, I don't have any installation guidance but I have a question: Do you know where I can get squeegies and channels? (and new door stripping) ('73 620) Thanks. Quote Link to comment
sammym Posted May 19, 2014 Author Report Share Posted May 19, 2014 I tried contact cement on the channels... didn't work for me. They slowly work their way down with the window. The squeegees just clip in. Take your time. Thanks, Can you please describe how the clips work? What is the procedure with them? Quote Link to comment
sammym Posted May 19, 2014 Author Report Share Posted May 19, 2014 I used the right stuff instead of contact cement on saggy channel felt with good results. The Right Stuff gasket stuff? How did you apply? Thank You. Quote Link to comment
]2eDeYe Posted May 19, 2014 Report Share Posted May 19, 2014 Yep the gasket stuff, it makes a good adhesive as well. Straight outta the tube into the door channel, 1/8 bead or so, insert the felt channel, then roll up the window tight and leave it overnight. The clips on the squeegees are easiest to deal with if you remove the window first, you can pop them out of their little pocket with a flathead from inside the door. Quote Link to comment
JCalais Posted May 20, 2014 Report Share Posted May 20, 2014 I have just brought new window door rubbers, quater window rubbers and window felt, ordering new front, rear and squeegees this week. Will update on how i go getting them all on. hopefully its not to hard and all fits well Quote Link to comment
]2eDeYe Posted May 20, 2014 Report Share Posted May 20, 2014 These show the squeegee clips, didn't get any of the felt channel. Quote Link to comment
5t341tH Posted May 20, 2014 Report Share Posted May 20, 2014 Is it best to remove the glass first before doing any of this or can it be left in? Quote Link to comment
ADavis_620 Posted July 11, 2014 Report Share Posted July 11, 2014 Im getting ready to do this tomorrow. Hopefully though i have everything i need. i want to wash the truck so bad. Quote Link to comment
ADavis_620 Posted July 11, 2014 Report Share Posted July 11, 2014 Is it best to remove the glass first before doing any of this or can it be left in? Im getting ready to do this tomorrow. Hopefully though i have everything i need. i want to wash the truck so bad. I don't think it matters if window is in or not. Quote Link to comment
]2eDeYe Posted July 11, 2014 Report Share Posted July 11, 2014 You will want to remove the windows or you risk damaging the seals. Quote Link to comment
thisismatt Posted July 11, 2014 Report Share Posted July 11, 2014 Yup, remove the glass. The squeegee clips can be a real pain to get out. Quote Link to comment
anohurry Posted July 11, 2014 Report Share Posted July 11, 2014 I'm a newbie but I tried the window channel installation using felt channels I bought on eBay from some outfit in Singapore. They were junk. I think I used contact adhesive to place them in the channels but they worked out. While trying to work them back in they tore and I ended up yanking them out. I'm now driving around with my windows rattling. I wonder where I can find quality channel guides that fit. Quote Link to comment
DanielC Posted July 11, 2014 Report Share Posted July 11, 2014 On a 521, window crank, door open lever, remove door panel. Remove the plastic covers over then holes in the door. Remove door window stop. Disconnect roller on window regulator from door glass. Lower window to bottom of door. Then you can remove the window weather strips. Try not to bend it. Carefully pry it up with a screwdriver, using a cloth to pad painted surfaces, if necessary. I recommend you put the screws you remove from door parts back into the part, after the part is removed from the door. I know, this is a 620 question. But I only have 521 trucks, and a factory service manual for a 521. I am assuming (I know) the 620 is similar. I found this new run channel, from Mygrant Glass. It worked good in a 521. You will have to contact an auto glass supplier to get it. This is a better picture of the part number of the run channel. This is a picture of the cross section of the run channel. This is the weatherstrip cement I used to glue the window run channel in the door. The box the weather strip cement comes in. Part number of the weather strip cement. The weather strip cement also comes in a yellow color. This stuff sticks to every thing really good, especially fingers. You can wear latex or nitrile gloves, but it sticks to them really well, too. 2 Quote Link to comment
GRpufnstuf Posted July 12, 2014 Report Share Posted July 12, 2014 make sure to get the middle of the Squeegee stretched out and flat. on mine the clips had to be rearranged and then i trimmed the ends. at first i left a little slack in the middle and the rubber startwd to bow up. they are softer than the original (i think) so they grip the glass when it rolls down Quote Link to comment
abbylind Posted December 9, 2014 Report Share Posted December 9, 2014 I just installed the squeegies on mine. Save the clips off the old squeegee. 2 of the clips broke on the new squeegies so I recycled the old ones. Installing window felt tomorrow Quote Link to comment
abbylind Posted December 14, 2014 Report Share Posted December 14, 2014 Installed the felt on the drivers side. I pushed the felt up on the front side of the door and down on the back side, Didnt have to remove the window. Just cranked it up and down as I moved the felt. I didnt use any glue on the felt as it snapped in pretty well by itself. Nice to have a rattle free window...Passenger side is next Quote Link to comment
red13 Posted March 19, 2016 Report Share Posted March 19, 2016 Good info good to know whenm tear my doors apart to fix Quote Link to comment
Scgreen620 Posted January 4, 2017 Report Share Posted January 4, 2017 On a 521, window crank, door open lever, remove door panel. Remove the plastic covers over then holes in the door. Remove door window stop. Disconnect roller on window regulator from door glass. Lower window to bottom of door. Then you can remove the window weather strips. Try not to bend it. Carefully pry it up with a screwdriver, using a cloth to pad painted surfaces, if necessary. I recommend you put the screws you remove from door parts back into the part, after the part is removed from the door. I know, this is a 620 question. But I only have 521 trucks, and a factory service manual for a 521. I am assuming (I know) the 620 is similar. I found this new run channel, from Mygrant Glass. It worked good in a 521. You will have to contact an auto glass supplier to get it. This is a better picture of the part number of the run channel. This is a picture of the cross section of the run channel. This is the weatherstrip cement I used to glue the window run channel in the door. The box the weather strip cement comes in. Part number of the weather strip cement. The weather strip cement also comes in a yellow color. This stuff sticks to every thing really good, especially fingers. You can wear latex or nitrile gloves, but it sticks to them really well, too. That part and the number were perfect installed it on mine nice and tight but I do have to use the adhesive.. Other than that looks good and fits perfect Quote Link to comment
