datson4life Posted May 13, 2014 Report Share Posted May 13, 2014 Heres the issue, in 5th gear 3.5k rpm to 4.5k rpm, there is alot of vibration, after 4.5k rpm its super soft Does drive line need rebalancing, or does that sound like a transmission issue? Ka24de with ka tranny One piece driveline Quote Link to comment
ggzilla Posted May 13, 2014 Report Share Posted May 13, 2014 Sounds like a driveshaft issue. Quote Link to comment
kelowg Posted May 13, 2014 Report Share Posted May 13, 2014 But at those rpm sitting still in nuetral does still do it? Also ck in N rolling down the road. That well help narrow it down. Quote Link to comment
ggzilla Posted May 13, 2014 Report Share Posted May 13, 2014 If it does it in neutral, suspect the driveshaft. It is unlikely to be transmission unless its the tailshaft bushing Quote Link to comment
datzenmike Posted May 13, 2014 Report Share Posted May 13, 2014 The driveshaft has to be custom so look for damage like a dent that may have put a very small wow in it. Look for a clean patch near either U joint where a balance weight may have recently fallen off. Last, inspect the U joints for ANY looseness in any direction, other than just turning. If not sure replace joint. 1 Quote Link to comment
datson4life Posted May 14, 2014 Author Report Share Posted May 14, 2014 Thanks for input, yea at tgat speed if i drop to neutral its soft, ill check driveline Quote Link to comment
bryant2482 Posted June 12, 2014 Report Share Posted June 12, 2014 check to see if maybe one of your friends taped a nut to the drive shaft as a prank haha :rofl: :rofl: Quote Link to comment
