bryant2482 Posted May 12, 2014 Report Share Posted May 12, 2014 I changed my front brakes yesterday and noticed that my tires on both sides are already balding after 1 year from being new. My truck has no visible camber and the alignment seems good. The inside is worn a bit more then the outside. Anyone have this issue before? Quote Link to comment
datzenmike Posted May 12, 2014 Report Share Posted May 12, 2014 Get a small magnetic torpedo level and set vertically on the rim edge with the truck parked level side to side. Eyes can be deceived. Are the tops tilted in? Have someone drive straight ahead and direct them to turn the front wheels so the drivers side front lines up with the rear. Just look down the side walls until they are facing forward exactly. Now look at the pass side front wheel. It it noticeably turned out or in? compared to the rear one behind it? Quote Link to comment
banzai510(hainz) Posted May 12, 2014 Report Share Posted May 12, 2014 in dought just get the front end alighed. My 510 did the same. to much toe out was my proplem Quote Link to comment
datzenmike Posted May 12, 2014 Report Share Posted May 12, 2014 Worn out steering and suspension parts can also do this. Be sure everything is good before alignment or it's a waste of time and money. Quote Link to comment
MikeRL411 Posted May 12, 2014 Report Share Posted May 12, 2014 Also, if you are running larger and wider tires than the standard, check your air pressure. You might need a few extra PSI to get the correct tire patch on the ground. Too little pressure and you will have excess wear on the outside tread. Quote Link to comment
bryant2482 Posted May 12, 2014 Author Report Share Posted May 12, 2014 ill bleed out the excess air in the tires to the correct amount and take it from there. i know that my bushings will have to be replaced one of these days as well Quote Link to comment
banzai510(hainz) Posted May 12, 2014 Report Share Posted May 12, 2014 I could see that my tires were toed out. How about cking. then pay the 50$ to get it aligned at Les Schwab They do a good job and will tell you. I have my 521 10 years and never had the front end done besides Kingpins and it still great. has this been wrecked? Quote Link to comment
izzo Posted May 12, 2014 Report Share Posted May 12, 2014 doesnt matter. Replace ball joints, or king pins. replace any steering pieces that are worn out. Generally its camber or toe that causes the insides to go bald, ball joints/king pins are also culprits. I just went thru this... Ball joints may not look bad, but they can be! Once you replace those, do an alignment. replace upper and lower A-Arm bushings, too. (before alignment) Quote Link to comment
