Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 I don't want to cut it though. As I'll still have the pain of removing both ends then... 1 Quote Link to comment
Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 So this is how it sits for now... 2 Quote Link to comment
Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 I'm shopping for something like this online: To get at it here: 1 Quote Link to comment
Gradyfest Posted May 29, 2015 Author Report Share Posted May 29, 2015 It's a flare nut crowfoot (in case somebody didn't know.) This will actually be the first one in my tool kit. I'm actually looking for a set if the price is right. It seems most the sets end at 24mm, perfect. I might just get the one though. Before this I've never had a reason to need one... 2 Quote Link to comment
Charlie69 Posted May 29, 2015 Report Share Posted May 29, 2015 Thanks guys. I'm still hesitant on pulling the motor and have to fit the the time in. But while it's in the drive way I thought I'd fix the exhaust leak at the manifold. It's making it not fun to drive. I'm in the middle of pulling the intake and exhaust manifold bolts off right now. What a pain in the ass! Some of these bolts seem impossible. The 12mm swivel socket has been the hero of the day so far. On the hard to get to bottom bolts I use a 1/4" ratchet, 12" extension, and a 12mm swivel socket. I run the engine until it is warm and then I put the longest wrench I have on the nut and then I hit the wrench with a BFH! If this does not work I cut the pipe so it can be welded back together. 1 Quote Link to comment
Gradyfest Posted May 30, 2015 Author Report Share Posted May 30, 2015 I ordered this off Amazon. Got it Prime for 51 bucks! I'll get that damn EGR tube off intact before it's over. 2 Quote Link to comment
Gradyfest Posted May 30, 2015 Author Report Share Posted May 30, 2015 I also got these off eBay to help ease the job as well. The 12mm swivel socket I have now is a 3/8" drive and it's a little to bulky in some spots. 2 Quote Link to comment
Gradyfest Posted May 30, 2015 Author Report Share Posted May 30, 2015 So while I wait on all that to come in the mail, I decided to fix my leaking valve cover gasket and do a cold valve lash adjustment while I was at it. I'm almost at 45K and figure it's about time anyways. I started educating myself on the subject here, and found this post most helpful: http://community.ratsun.net/topic/35475-valve-cleance-on-l20b/?hl=%2Bengine+%2Bcold+%2Bvalve+%2Badjustment&do=findComment&comment=546337 1 Quote Link to comment
Gradyfest Posted May 30, 2015 Author Report Share Posted May 30, 2015 I then watched a YouTube video on it that I found by searching "Datsun valve lash," (this is the first valve clearance adjustment I've done.) But it's this page in the service manual that made things stress free though: 1 Quote Link to comment
Gradyfest Posted May 30, 2015 Author Report Share Posted May 30, 2015 It was weird when I got in their though. All my intakes were 0.006 and I couldn't even get my smallest feeler gauge that was the 0.006 in the exhausts! They were all way to tight. Now in my educating myself I read how a few guys did 0.008 intake and 0.010 exhaust cold but still had "chatter." I mulled that information over a little bit and decided to leave all the intakes alone at 0.006 and go ahead and set all the exhausts at 0.008, so that's what I did. It ran great before anyways and a little tight can't hurt right? Hell its got to better now anyways, since those exhaust valves were so tight. I couldn't believe it. The previous owners mechanic sucked and of course he put RTV on the valve cover gasket, why? I hate, hate, hate RTV. Cleaning it is never fun. 2 Quote Link to comment
DrvnDrvr Posted May 31, 2015 Report Share Posted May 31, 2015 The previous owners mechanic sucked and of course he put RTV on the valve cover gasket, why? I hate, hate, hate RTV. Cleaning it is never fun. The PO of my 720 put RTV on the carb gasket and it still leaked. What a mess. Cleaned it up and got a new gasket for my 38 Weber and used a little Vasoline. Wa Laa, No leaks and clean as hell. I replaced the cork and RTV semi-sealed valve cover gasket with a rubber one and a little Vasoline. Used a little RTV on the half circle insets as per the FSM and that took care of those leaks. Took Dmike's advice and re-torqued the head bolts,needed it, and adjusted the valve clearance to FSM specs. Changed oil to quality 40w to quiet timing chain tensioner. Yes, that works. Idles smooth, clean, and quiet. When I put my foot into it that 720. it roars to life and takes off like a bat outta hell. Love the low end torque! Yeah, sure I'm only getting 18 mpg but I'm in 4x low blasting over hill and hell's highway catching air every chance I get. Thanks to all the Ratsun members and staff for the info to help me make my 720 a daily driver and a thrill to drive. :thumbup: :thumbup: :thumbup: 2 Quote Link to comment
KiloTango1200 Posted May 31, 2015 Report Share Posted May 31, 2015 For the fittings and bolts that don't want to come out, a MAP gas torch will save the day. But use it carefully as MAP gas burns much hotter than propane. 2 Quote Link to comment
Gradyfest Posted June 3, 2015 Author Report Share Posted June 3, 2015 Photos from the previous job I mentioned: 3 Quote Link to comment
Gradyfest Posted June 3, 2015 Author Report Share Posted June 3, 2015 Can someone tell me if this is supposed to be like this? Is this JB Weld? 2 Quote Link to comment
Gradyfest Posted June 3, 2015 Author Report Share Posted June 3, 2015 My hasty tools of the trade: Pen lid: BBQ skewer: Q-tip after the clean rag for tight spots and bolt holes: 1 Quote Link to comment
Gradyfest Posted June 3, 2015 Author Report Share Posted June 3, 2015 I pulled the spark plugs so it would rotate with ease when I did the valve clearance adjustment. 1 Quote Link to comment
Draker Posted June 3, 2015 Report Share Posted June 3, 2015 A good way to remove that rtv easily is with a yellow roloc disk. Yellow only. 1 Quote Link to comment
Gradyfest Posted June 4, 2015 Author Report Share Posted June 4, 2015 Thanks for the tip Draker, I've never heard of that. I'm going to look it up. 1 Quote Link to comment
