mickey-d Posted May 5, 2014 Report Share Posted May 5, 2014 Hi, new here and would welcome some educated opinions. I'm a new owner of a 1984 sentra xe 1.6L E16, and have come accross this statement a few times. " the e-series was prone to head gasket failure " 1st - is this a true statement, and if so, does anyone know if its caused by inferior gasket material, head warping, or cracking. 2nd - I have good compression in all cylinders right now, and am considering retorqueing the head bolts. Is this a good idea, or should I leave them alone? 3rd - Are there any other common problems assosciated with the 1984 sentra I should be aware of ? Any help would be greatly appreciated. Thanks mickey-d Quote Link to comment
datzenmike Posted May 5, 2014 Report Share Posted May 5, 2014 I've never heard that but it's possible it is said. The Z24 motor in the 720 is well known for this and the preventative is to re torque the head bolts at every tune up. Which is easy enough and not rocket science. Do on a cold motor. Loosen only one bolt at a time and tighten directly to the recommended torque. You can do in any order but only one at a time. Quote Link to comment
ggzilla Posted May 6, 2014 Report Share Posted May 6, 2014 The statement means more than usual will blow a head gasket. But most Sentras never have and never will blow a gasket. I believe it is caused by overheating. Yes, retorque the head. The owners manual I believe will give the maintenance schedule. Quote Link to comment
mickey-d Posted May 6, 2014 Author Report Share Posted May 6, 2014 Thanks for the advice. Very glad to hear you guys don't consider that a common problem with the e-series. Will be retorqueing head bolts today...one at a time. I can see already that RATSUN is a great site to have joined. Will be back with many more questions, I'm sure Thanks again mickey-d Quote Link to comment
ggzilla Posted May 6, 2014 Report Share Posted May 6, 2014 It is a common problem. But that doesn't mean it will occur, only that it happens more often than with other engines. Quote Link to comment
