datzenmike Posted May 19, 2014 Report Share Posted May 19, 2014 Washers perhaps. The bolt can be tightened a bit but don't over squeeze those two fingers together too much and break them. Also the join between shifter and striker rod must be just loose enough to work like a door hinge. Quote Link to comment
stheodore10 Posted May 20, 2014 Author Report Share Posted May 20, 2014 so i grinded down two washers to perfect size and slipped them in and im not sure how but it popped out of gear and everything seems fine :confused: :hyper: im not sure how or why this worked but thank you all esp datzenmike 1 Quote Link to comment
datzenmike Posted July 27, 2014 Report Share Posted July 27, 2014 Owned a 521 for 8 years. The shifter could be moved in a circle the size of a basketball it was so worn. Is it any wonder these A series transmissions were referred to as the 'Monkey Motion' shifter? A well earned title. Quote Link to comment
