MicroMachinery Posted February 25, 2015 Report Share Posted February 25, 2015 Pretty sure I used to own that dogleg 5 spd.. edit: Nevermind. I know I used to :lol: 1 Quote Link to comment
Oscarmaier Posted March 11, 2015 Author Report Share Posted March 11, 2015 Got some work done over the weekend. ...and two shall become one. Left: 32/36 DGAV (found in the back of an old Volvo at the wrecking yard). Right: 32/36 DGEV (Came with the car). Quote Link to comment
Draker Posted March 11, 2015 Report Share Posted March 11, 2015 Got some work done over the weekend. Are these jetted the same? Any interest in selling some of the extras? Quote Link to comment
the510keeper Posted March 12, 2015 Report Share Posted March 12, 2015 The white wheels look great on that orange dime 1 Quote Link to comment
Oscarmaier Posted March 12, 2015 Author Report Share Posted March 12, 2015 Thanks. Originally I didn't like the white when I bought them, but as soon as they were on the car I knew I had to go all white. The fronts don't fit quite right, they poke about 1" and rub over dips. Quote Link to comment
Oscarmaier Posted March 12, 2015 Author Report Share Posted March 12, 2015 Not sure about the jets just yet. These are the first carbs that I have ever really gone through, learning as I go. I could part with some of the extras, I'll let you know what I have left over when I'm done. I have a set of 240 SU's that will go on at a later date, I am just trying to get this thing done for Canby. So much work, so little time. Quote Link to comment
Draker Posted March 12, 2015 Report Share Posted March 12, 2015 Not sure about the jets just yet. These are the first carbs that I have ever really gone through, learning as I go. I could part with some of the extras, I'll let you know what I have left over when I'm done. I have a set of 240 SU's that will go on at a later date, I am just trying to get this thing done for Canby. So much work, so little time. Cool.. this is what should be in them for an L motor. Main Venturi: 26/27 Aux Venturi: 3.5/3.5 Main Jet: 140/135 Em Tube: F50/F6 Air Corr Jet: 165/160 Idle Jet: 55/50 Pump Jet: 50 Needle Valve: 2.00 1 Quote Link to comment
Oscarmaier Posted March 12, 2015 Author Report Share Posted March 12, 2015 Thanks for the info Draker Quote Link to comment
banzai510(hainz) Posted March 13, 2015 Report Share Posted March 13, 2015 I have seen 140 to 130 in the mains. Most times thay all run fine. just be leary on the carbs. I see people fuck with them and they just worn out. I didnt know how bad my 521 weber was till I finally put a new one on and runs alot better. Quote Link to comment
Oscarmaier Posted March 16, 2015 Author Report Share Posted March 16, 2015 I have seen 140 to 130 in the mains. Most times thay all run fine.just be leary on the carbs. I see people fuck with them and they just worn out.I didnt know how bad my 521 weber was till I finally put a new one on and runs alot better. The choke on mine was all sorts of messed up when I got it that the shaft had worn out the upper housing. I'm just swapping the good upper housing onto the lower body because I want to keep the electronic choke, and replacing seals and gaskets. Then just adjust it properly so I can drive it until I get the SU's sorted out. Quote Link to comment
Oscarmaier Posted March 16, 2015 Author Report Share Posted March 16, 2015 No progress this weekend. It's been raining like crazy all weekend and the front half of my garage has about half an inch of standing water in it. Luckily no damage but quite the mess, I don't have enough room to clean it up until it stops raining. Also the wife had to work all weekend, so I've got kid detail. Quote Link to comment
Oscarmaier Posted March 26, 2016 Author Report Share Posted March 26, 2016 Wow! How has it been a year since I last updated this. Not much has been done on the car, but I've been dailying it since September and slowly discovering things that need attention. This is an older picture but since it was taken I've cleaned up the wiring some, replaced the battery with one that actually fits on the tray, installed a 60 amp 240z alternator, replaced the clutch master and slave cylinders (both where leaking so badly that the reservoir would go dry overnight) I had an alignment issue that was causing the car to pull to the left pretty hard, found out my rear axle was pointed about .50* to the right and my right front caster was +2.00* out of spec (I don't remember the actual amount) I squared the rear and aligned the front end, its much better but still pulls to the left and is pretty squirrely on really rutted roads. This car was in an accident at some point in its life and a section of the front frame was cut out and grafted in from another car, I'm pretty sure that's my caster issue. looks like I'll be getting a set of T3 adjustable T/C rods. . Picked up a set of Enkei 92's in 14x6 +15 offset, the fitment wasn't great in the rear so I decided to run the mismatched set, but I wanted them all the same color. Quote Link to comment
Oscarmaier Posted March 27, 2016 Author Report Share Posted March 27, 2016 Spent a couple of hours yesterday washing, scrubbing and polishing this turd. Man I love that color. 2 Quote Link to comment
Oscarmaier Posted March 28, 2016 Author Report Share Posted March 28, 2016 Beautiful! Thanks. It's amazing what a little elbow grease can do Quote Link to comment
Eagle_Adam Posted March 28, 2016 Report Share Posted March 28, 2016 The white on orange is on point!! Quote Link to comment
Oscarmaier Posted April 29, 2016 Author Report Share Posted April 29, 2016 well that's awesome, my photobucket account just deleted all of my photos. Quote Link to comment
banzai510(hainz) Posted April 29, 2016 Report Share Posted April 29, 2016 I would clean up the distributor wires to the + and - to the coil. cross them over till you get to the coil. Quote Link to comment
Oscarmaier Posted June 28, 2017 Author Report Share Posted June 28, 2017 Long time no post, here is a visual of the progress I've been up to. I have other things too, but that will be an actual post. 3 Quote Link to comment
Charlie69 Posted June 28, 2017 Report Share Posted June 28, 2017 Interior looks tits man. 2 Quote Link to comment
Duncan Posted June 28, 2017 Report Share Posted June 28, 2017 I think this is the first time I have seen your thread. Sweet goon! I was going to paint mine 69 Camaro Hugger Orange, then two wagons showed up in the area painted hugger orange! I'm happy with the blue I went with, but I do love that orange.. Quote Link to comment
racerx Posted June 28, 2017 Report Share Posted June 28, 2017 Like the steering wheel and the fact you kept the seats stock...nice work! 1 Quote Link to comment
Oscarmaier Posted June 28, 2017 Author Report Share Posted June 28, 2017 Like the steering wheel and the fact you kept the seats stock...nice work! Thanks, the steering wheel is from an early 240z and the seats are actually BMW e30, but stock looking was the goal. Quote Link to comment
Oscarmaier Posted June 28, 2017 Author Report Share Posted June 28, 2017 I think this is the first time I have seen your thread. Sweet goon! I was going to paint mine 69 Camaro Hugger Orange, then two wagons showed up in the area painted hugger orange! I'm happy with the blue I went with, but I do love that orange.. Thanks Duncan, I love your wagon and the progress is awesome, keep up the great work. Quote Link to comment
Oscarmaier Posted June 29, 2017 Author Report Share Posted June 29, 2017 Summer Fall Winter installed T3 adjustable TC rods Made a battery hold down Got a roof rack to get some work done around the house 3 Quote Link to comment
