jeph Posted April 24, 2014 Report Share Posted April 24, 2014 i just bought a 510 4 door and it has coilovers on the front with camber plates but the nut on top that threads onto the actual shock is only on by like 2 threads on both sides and wont tighten any more? anyone have this problem? ill get pics later Quote Link to comment
q-tip Posted April 28, 2014 Report Share Posted April 28, 2014 I'm running ground control camber plates, and I haven't seen any camber plates that were too thick for the strut top to go thru. Do you know what struts are on the car? Quote Link to comment
edekalil Posted April 30, 2014 Report Share Posted April 30, 2014 Have any pics? Quote Link to comment
jeph Posted April 30, 2014 Author Report Share Posted April 30, 2014 im not sure what inserts they are but i do know their different from eachother because the allen size in the center is different on both sides, i even tried to impact them down more and that is as far as they go. im stumped.. Quote Link to comment
ggzilla Posted April 30, 2014 Report Share Posted April 30, 2014 Don't be stumped. Get new good strut inserts. 2 Quote Link to comment
q-tip Posted April 30, 2014 Report Share Posted April 30, 2014 Don't be stumped. Get new good strut inserts. This! Quote Link to comment
banzai510(hainz) Posted April 30, 2014 Report Share Posted April 30, 2014 I know on my konis that they were not the jap spec threads and I gotten a insert bushing from T3 or soemthing. or vise versa.. I think I have more than 2 threads. The guy at T3 knoew what I was saying ,said Oh you have this. as other say maybe get another set of insert but might still have same issue. You sure. You might have more than 2 threads as I see a shank below the Hex and I know these are 1 pc. Quote Link to comment
jeph Posted May 1, 2014 Author Report Share Posted May 1, 2014 i was kinda reading around and it looks like i should buy mr2 inserts is that sound right? i dont believe i have 280z struts because i bought regular 510 brake pads and they fit on the car but i do have adjustable coilovers on it. Quote Link to comment
ggzilla Posted May 1, 2014 Report Share Posted May 1, 2014 I would use 280ZX inserts. They fit 510 struts using spaces, which MR2 inserts also require. But first make sure your left & right struts match. Clean the outside of the strut tube to read the part number. 1 Quote Link to comment
q-tip Posted May 1, 2014 Report Share Posted May 1, 2014 The Mr 2 insert is going to be 4" shorter than the stock 510 strut. Zx struts will only be 2" shorter. 2 Quote Link to comment
hobbes_the_cat Posted May 2, 2014 Report Share Posted May 2, 2014 Measure your struts. They may have been shortened for a different insert as that is a fairly common thing to do when going real low. If you see a spot where they were welded all the way around the tube, they are probably not stock length. You don't want to buy new inserts that are too long. Quote Link to comment
edekalil Posted May 7, 2014 Report Share Posted May 7, 2014 Here is a shot of one of a set of camber plates I bought off eBay. They where a generic type. I had to bring the inserts to a machine shop to have a small amount of the top part the shaft turned down so they would fit the camber plate better. I'm not sure they are the same as the ones you have in the pic. 1 Quote Link to comment
