210 ka24 idling high
Last King
  • Replies 6
Does it warm up correctly or does it just hold high idle after warmup. There is a bimetal (thermal electric) air regulator on the intake that may not be hooked up causing idle to not drop after warmup. If all of that is good I would check to see if your brake booster is leaking allowing extra air in.
