LUIS COLCHETE Posted April 22, 2014 Report Share Posted April 22, 2014 Hi! Im updating my Datsun B110, recently i bought 2 mikunis 40phh and a intake mainfold. Im trying to adapt them (i ve posted in fórum). To upgrade I need to discover a compatible camshaft, who makes them, if are new or who regrind them Please advise me and where i can find one at a good price. Many thanks Luis Quote Link to comment
ggzilla Posted April 22, 2014 Report Share Posted April 22, 2014 With twin carbs, the factory camshaft works very well. It pulls from 2000-6000 rpm. Quote Link to comment
LUIS COLCHETE Posted April 22, 2014 Author Report Share Posted April 22, 2014 Thanks a lot Quote Link to comment
ggzilla Posted April 22, 2014 Report Share Posted April 22, 2014 The larger carburetors will wake up a 1200! Will run better at 5000 to 6000 rpm than with the stock small carburetor. Quote Link to comment
LUIS COLCHETE Posted April 28, 2014 Author Report Share Posted April 28, 2014 Hi! If i send my actual camshaft to grind, i will need to modify another componentes? Double Springs (i think its need). Many thanks, Luis Quote Link to comment
datzenmike Posted April 28, 2014 Report Share Posted April 28, 2014 Most Nissan engines are already double spring. You may simply need stiffer spring. ggzilla will know. Quote Link to comment
LUIS COLCHETE Posted April 28, 2014 Author Report Share Posted April 28, 2014 Im consider to send my camshaft to regrind it 175,00 £ in(United Kingdom) Please advise me which are the best: Duration of intake and exhahust valves for my twin 40 carbs. From 248/248 original to 260/260 265/265 ?????? I dont want a racing car but i only want a better performance enginee. You told me that a twin carbs will wake my Datsun. But the camshaft greatly improve? What componentes i have to change? Or mount the camshaft without any modifications? Many thanks Luis Quote Link to comment
datzenmike Posted April 28, 2014 Report Share Posted April 28, 2014 I wouldn't go over 270 for a street car, while other's might. Increasing lift will also add some power without changing how well it runs at low speeds. If driving around town it should run fairly well without too much down side that's hard to live with. 175 Pounds? Couldn't you just buy a new cam for that much? Quote Link to comment
LUIS COLCHETE Posted April 28, 2014 Author Report Share Posted April 28, 2014 Where? Please advice me, Im in Eurpoe. I can try in USA or Austrália, the problema is the customers. Anybody share the store to buy a new one or i where i can regrind it Thanks Luis Quote Link to comment
ggzilla Posted April 28, 2014 Report Share Posted April 28, 2014 If i send my actual camshaft to grind, i will need to modify another componentes? Double Springs (i think its need). When you arrange to send it, ask the grinder what the cam grind requires. Stock A-series valve springs are good for 6000-6400 rpm. Most Nissan engines are already double spring. You may simply need stiffer spring.Nissan A-series engines have single springs. Only a few,special models got doubles, good for 6400-6800 rpm. You only need stiffer springs if revving higher. Or if the cam grind is unusually aggressive. Quote Link to comment
ggzilla Posted April 28, 2014 Report Share Posted April 28, 2014 175 Pounds? Couldn't you just buy a new cam for that much?Order from Isky in USA only $100 usd (59 £). Iskenderian 266/256 - 24/62/24/62 This is a little longer duration than the factory GX grind, which does 6400 rpm for 1.2 litre. http://www.iskycams.com/ Quote Link to comment
ggzilla Posted April 28, 2014 Report Share Posted April 28, 2014 Please advise me which are the best: Duration of intake and exhahust valves for my twin 40 carbs. I dont want a racing car but i only want a better performance enginee. You told me that a twin carbs will wake my Datsun. But the camshaft greatly improve? I would use the stock A12 camshaft, which makes peak HP at 6000 rpm. However, the stock carburetor is overly small for superior fuel economy and driveability+flexibility. The stock cam and cylinder head are very capable, but the carb strangles it slightly. Twin 40s will wake an A12 up. Between 5000-6000 rpm the larger carburetor will make a big difference. Try it and see. Quote Link to comment
LUIS COLCHETE Posted April 28, 2014 Author Report Share Posted April 28, 2014 Hi Many thanks for your precious advice. Keep on to clarify... First of all i will mount the motorhead, fit the intake mainfold and grind the exhaust mainfold and finally test the carbs. Second i will not buy the cam... Your word its enough for me By the way, please advice me a good shop where i can buy spares at a fair price i (water pump, gas pump, door rubers, winchield rubbers) everything for my Dat Many thanks Luis Quote Link to comment
ggzilla Posted April 28, 2014 Report Share Posted April 28, 2014 I do not know of a shop in Europe. RockAuto.com has good selection and prices, but their shipping options are expensive. Perhaps ask datsunbat in PT. Quote Link to comment
LUIS COLCHETE Posted April 28, 2014 Author Report Share Posted April 28, 2014 Thanks I will see your contacts. Quote Link to comment
LUIS COLCHETE Posted September 11, 2014 Author Report Share Posted September 11, 2014 HI! I m intend to get some performance parts for my Datsun a12 engine so I`ve sent a couple of e-mails to contact the Iskenderian shop, but at the moment i cant get any answer from them. I must be registered on site? I ve seen they dont have any actualized catalog.? The shop still exists? Anybody recently had bought some itens? Which is the best way to contact them? Please give me the best contact.... Many thanks on advance Luis Colchete Quote Link to comment
LUIS COLCHETE Posted September 11, 2014 Author Report Share Posted September 11, 2014 Please let me know, if anybody had bought from ISKENDERIAN SHOP recently Quote Link to comment
LUIS COLCHETE Posted September 11, 2014 Author Report Share Posted September 11, 2014 Please give me the contacts to the ISKENDERIAN SHOP, i ve contact them, but at the moment i dont have any answer from them. I want to know if they got performance parts for Datsun A12 Engine. Anybody who bought itens, let me know, or where i can find, a performance cam, and another parts.... Quote Link to comment
LUIS COLCHETE Posted September 11, 2014 Author Report Share Posted September 11, 2014 Anybody..... King Rat.... I need to contact Quote Link to comment
LUIS COLCHETE Posted September 16, 2014 Author Report Share Posted September 16, 2014 Hi! Which is the best way to contact the Iskenderian Shop? I ve sent e-mail and fax, and nothing..... at the moment i dont have any answer Quote Link to comment
datzenmike Posted September 17, 2014 Report Share Posted September 17, 2014 From their site.... ed iskendarian racing cams16020 s. broadwaygardena ca 90248phone: 323.770.0930fax: 310.515.5730 Catalog ..... http://www.iskycams.com/onlinecatalog.html Summit Racing has Isky cams?... http://www.summitracing.com/int/search/brand/isky-racing-cams Quote Link to comment
LUIS COLCHETE Posted September 17, 2014 Author Report Share Posted September 17, 2014 Thanks! I sent a fax.. my fax machine informe me they received it. Im expecting, a day, a week, a month, i dont know how much Many thanks Luis Quote Link to comment
LUIS COLCHETE Posted September 18, 2014 Author Report Share Posted September 18, 2014 Hi! The best way is caling..... Nice People I will regrind my original cam as ggzilla said.... By the way where is ggzilla....... source of knowledge Quote Link to comment
LUIS COLCHETE Posted September 21, 2014 Author Report Share Posted September 21, 2014 Hi! Tomorrow i will send my camshaft to Iskenderian shop to regrind it. I m pretending to buy double valve springs. but i have a doubt A12 and A14 valve springs have the same size???. I took a measure and A14 valve springs are a bit taller im confused... it is correct? Because i ve seen some persons saying they are equal! Anybody knows... Quote Link to comment
datzenmike Posted September 21, 2014 Report Share Posted September 21, 2014 A12/14/15 valve springs are all the same part number. Haven't heard from ggzilla in a month at least. Quote Link to comment
