When using spacers
edekalil
  • Replies 14
Well I am trying to get some info together so I can plan to use my 300zx rims on the 72/510 I just got up and going again.Busta Nut said he used 8mm in the rear and front I have to look at what struts he is using (I think shortend stock struts) so since I think I will keep the stock struts and just shorten them I should only need an 8mm spacer to work 1 per wheel. If I went with 280zx struts and brake set up I would need a thicker spacer in the front because the tires would sit closer inward. I plan to use the 280zx setup on another car which is apart at the moment. I cannot go way low due to the streets in New Orleans are not very slammed friendly. I do have some olde school components for lowering the rear of the car I think about 2 or more inches and I bought some newer coilover setup stuff with the smaller dia. springs I will use in the front. So that is what I will do so I can use the 300zx rims with good tires on them rather then let them sit any longer than they have.I will just start buying some newer components for when I get the last sedan put back together down the road here. I figured stacking would not be a good idea. My tire on that rim is 205x50r.
That shood work since I am not going to drop the car too much.
None of the spacers I have seen are designed well for stacking. Think Lego.. DatRod has the skills to get you a custom set made.
Skills???? Some would argue with you on that one. :rofl:
