So far so good
edekalil
Got my car back from the shop. It's up and running good at this time.
So far no temp problems nothing leaking. Needs a carb rebuild for sure (I have a kit ready). Still have to do some work on the brakes. It felt great to drive it again but now as a stick shift. Next stop is to have the muffler shop to cut the exuast pipe and weld a sleave around it so it can get the down pipe to mate to the exuast manafild with a new gasket. I put a different manafold on that motor and it lacks a little bit to much to pull together with out messing up the down pipe. Now to go find a few purrties for her like that Ratsun badge I saw that attaches to the front grill and a new shift knobs to match.
  • Replies 3
Yea they are the same as a friend of mine had on his new 1980 Toyota Celica way back. I had to have the center inner hole that fits the hub I guess you call it turned to fit on the 510. And thanks for the compliment on my car.
