jeph Posted April 30, 2014 Author Report Share Posted April 30, 2014 its electronic distributor, and i used a power probe on the ignition plug and turned the ignition on with it and started the car with it perfect then pluged it into the ignition and it wouldnt start. not sure what year sentra thats just what a friend told me they were out of they fit nice. Quote Link to comment
jeph Posted April 30, 2014 Author Report Share Posted April 30, 2014 oh and no tach or anything installed in this car all stock. Quote Link to comment
banzai510(hainz) Posted April 30, 2014 Report Share Posted April 30, 2014 guess im not getting this one. Ck the key switch connector under the colume since wiring is all stock should be a simple fix. If automatic then could be trans switch also 1 Quote Link to comment
jeph Posted May 1, 2014 Author Report Share Posted May 1, 2014 i just ordered a new ignition switch and ill try that out and see how it works. also going to install my new fuse box ive had laying around for years just to be safe since a couple of my fuses are melted around the edges. Quote Link to comment
jeph Posted May 1, 2014 Author Report Share Posted May 1, 2014 and thanks for the help everyone appreciate it. Quote Link to comment
mhub91 Posted May 1, 2014 Report Share Posted May 1, 2014 are you the same guy selling the rare starion wheels for $400 cause the tires are almost new? haha :poke: i was the guy on Facebook who shot you down and said they weren't worth more than $100 ............ only cause i wanted them. i see you're in tacoma.... hit me up sometime, i live here as well. 1 Quote Link to comment
jeph Posted May 1, 2014 Author Report Share Posted May 1, 2014 are you the same guy selling the rare starion wheels for $400 cause the tires are almost new? haha :poke: i was the guy on Facebook who shot you down and said they weren't worth more than $100 ............ only cause i wanted them. i see you're in tacoma.... hit me up sometime, i live here as well. haha yup that was me. i actually kept them because im going to trade them for body work and prep on the 510. Quote Link to comment
banzai510(hainz) Posted May 1, 2014 Report Share Posted May 1, 2014 not all fuse boxes are the same. i personally never see a key switch go bad with the 4 510s I owned I would see if somebody like Ted has a spare and just plug into the connector and use a screw driver to turn the new swtich and see if it works so you dont have to tear the whole key unit apart. Quote Link to comment
q-tip Posted May 1, 2014 Report Share Posted May 1, 2014 Its only two screws that hold the switch on the ignition, its easy enough to remove. Jeph, I have my old kinda iffy ignition switch still if you want to try that for a test 1 Quote Link to comment
jeph Posted May 2, 2014 Author Report Share Posted May 2, 2014 Its only two screws that hold the switch on the ignition, its easy enough to remove. Jeph, I have my old kinda iffy ignition switch still if you want to try that for a test i tried an ignition switch off of a 521 today and it started right up! i took mine off and it looks like someone used to start it with a screwdriver and then stuck it back in the ignition it was chewed up in there so the actual key wasnt turning it like it was supposed to. anyone know if the z car one will fit? http://www.ebay.com/itm/Datsun-240z-260z-280z-280zx-Ignition-Switch-NOS-/370988536551?pt=Motors_Car_Truck_Parts_Accessories&hash=item5660a3d2e7&vxp=mtr Quote Link to comment
jeph Posted May 2, 2014 Author Report Share Posted May 2, 2014 also went to install my new fusebox and all the extra wires were on my new one except the blue one that the people had hooked to the auto choke, which should be fine beings i took the filter off my carb and the flaps for the choke have been removed for some reason... so it should work out fine. Quote Link to comment
q-tip Posted May 2, 2014 Report Share Posted May 2, 2014 I say the switch is iffy because I don't remember if the switch was actually bad or if it ended up being a bad relay Quote Link to comment
banzai510(hainz) Posted May 2, 2014 Report Share Posted May 2, 2014 I think the Blue wire was used for the aircond (listed on the fuse box) one can use that to trigger a Can/Am box or choke or fuelpump ec..... will I guess you got it figured out. 1 Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 got bored today and started sanding, was getting tired of the poorly done walmart parking lot spray job lol Quote Link to comment
TENDRIL Posted May 3, 2014 Report Share Posted May 3, 2014 wheel and tire specs? Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 wheel and tire specs? just checked em and they are 15x7 konig rewind 0 offset with 10mm spacer in the rear tires are 205/50r15 Road Huggers 1 Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 so i seen this used before online and figured i would give it a try since finding lower panels is like gold and i dont make enough money to afford a brand new futofab replacement. so for 5$ im going to give this a try i know people are going to be like "your dumb" but thats fine. 1 Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 im going to shave that down then apply bondo over it. Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 what i got the idea from. Quote Link to comment
TENDRIL Posted May 3, 2014 Report Share Posted May 3, 2014 i think fiberglass filler would be better than bondo. :sweat: Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 i think fiberglass filler would be better than bondo. :sweat: alright ill look into that ive never used fiberglass before only bondo but cant be that much different process Quote Link to comment
TENDRIL Posted May 3, 2014 Report Share Posted May 3, 2014 well i say fiberglass because it would be a bit more forgiving with the elements, and overall wear and tear. pretty much the same process, just less absorbent than bondo, its right behind your wheels, you kick up a rock chip the paint, you live in the PNW water will soak the bondo like a sponge 1 Quote Link to comment
jeph Posted May 3, 2014 Author Report Share Posted May 3, 2014 well i say fiberglass because it would be a bit more forgiving with the elements, and overall wear and tear. pretty much the same process, just less absorbent than bondo, its right behind your wheels, you kick up a rock chip the paint, you live in the PNW water will soak the bondo like a sponge yup makes sense! thanks ill pick some up tomarrow and post more pics of the process Quote Link to comment
Hooligan Posted May 3, 2014 Report Share Posted May 3, 2014 Duraglass.... its a fiberglass based filler 3 Quote Link to comment
