datsunfreak Posted December 20, 2014 Report Share Posted December 20, 2014 Get newer steering knuckles. Problem solved. Or '68-69 ball joints. Same deal. Quote Link to comment
thisismatt Posted December 20, 2014 Report Share Posted December 20, 2014 Or '68-69 ball joints. Same deal. harder to find, weaker... Quote Link to comment
datsunfreak Posted December 20, 2014 Report Share Posted December 20, 2014 harder to find, weaker... Yeah, 'cause they break all the time... :rofl: Quote Link to comment
q-tip Posted December 20, 2014 Report Share Posted December 20, 2014 68's yes, 69's not all and depends on manufacture month of `69. I have a `69 built July of `69 and it has the 14mm. Very true. I would lean toward someone changing the knuckles somewhere in this dimes life. Quote Link to comment
jeph Posted December 24, 2014 Author Report Share Posted December 24, 2014 if i had the machine shop at my work bore the hole out to fit my ball joints would that work out or is that not safe? Quote Link to comment
q-tip Posted December 24, 2014 Report Share Posted December 24, 2014 The knuckles have a taper to match the ball joint, just drilling would be very much unsafe. 1 Quote Link to comment
jeph Posted December 25, 2014 Author Report Share Posted December 25, 2014 The knuckles have a taper to match the ball joint, just drilling would be very much unsafe. i meant with the proper taper and everything just bigger size, i remember reading somewhere on the 4x4 forums that they sell tapered drill bits that people have used on their knuckles to fit the bigger ball joint. Quote Link to comment
q-tip Posted December 25, 2014 Report Share Posted December 25, 2014 The taper on a ball joint or a tie rod end are not a standard taper, and I believe that Nissans was pretty much proprietary. I would have to measure one to be sure. It would be much easier to just find a pair of the bigger knuckles than go thru the trouble of getting a reamer and setting the knuckle at the proper angle. Quote Link to comment
jeph Posted December 27, 2014 Author Report Share Posted December 27, 2014 finally found the right bit, a buddy had one it was like 50$ or more so i was glad he let me use it, worked perfect only took 2 minutes. Good to go. also ran the fuel lines today, people with fuel injection, on the stock 510 hard lines is the bigger one the main line and the smaller one the return? Quote Link to comment
datsunfreak Posted December 27, 2014 Report Share Posted December 27, 2014 on the stock 510 hard lines is the bigger one the main line and the smaller one the return? The factory used the big line for the return and the small line for the feed. 1 Quote Link to comment
Josh K. Posted December 27, 2014 Report Share Posted December 27, 2014 You need at least 5/16" lines. 1 Quote Link to comment
jeph Posted December 28, 2014 Author Report Share Posted December 28, 2014 got the 7/8 master installed today. also dad got me a nice Christmas present 1 Quote Link to comment
jeph Posted December 29, 2014 Author Report Share Posted December 29, 2014 spent today taking the rest of the interior out and removing all the tar off the floor which was not fun lol. Now time to spend hours getting the surface rust off and prepping it for the por 15 and then putting down this. http://www.fatmat.com/shop/fatmat-bulk-packs-6561 had a buddo do the whole inside of his volvo rebuild and it worked great huge difference and great price. 1 Quote Link to comment
jeph Posted January 2, 2015 Author Report Share Posted January 2, 2015 got the e30 ellipsoids installed, will be nice to have hid's on here so i can actually see the road at night lol. also soaked and cleaned the fusebox at my work. 15 minutes in the ultrasonic cleaner at work and it came out like brand new Got most of the front suspension done all i need now is to rebuild the calipers, and order the ermish pitman arm bearing upgrade. 2 Quote Link to comment
jeph Posted January 3, 2015 Author Report Share Posted January 3, 2015 Blasted the caliper brackets today and changed the seals in the calipers. (before after) Its finally on the ground again! 1 Quote Link to comment
Trophy24 Posted January 3, 2015 Report Share Posted January 3, 2015 Lookin good. I bet it feels close now Quote Link to comment
Spoona_Jay21 Posted January 3, 2015 Report Share Posted January 3, 2015 Holy hell! At first I was upset you ditched the paint that was on it but this thing looks great now! Keep up the good work! Quote Link to comment
q-tip Posted January 3, 2015 Report Share Posted January 3, 2015 Blasted the caliper brackets today and changed the seals in the calipers. (before after) Its finally on the ground again! Let's get this on the new page.... 1 Quote Link to comment
jeph Posted January 13, 2015 Author Report Share Posted January 13, 2015 Not much of an update been really busy and broke lol living by myself and supporting my parents on 14$hr isnt helping this 510 lol But i did get a package in the mail from Josk K. with some bump steer spacers and i did get around to throwing them on. still need to save up for the ermish idle arm bushing/bearing upgrade and then the steering should be all done. 1 Quote Link to comment
jeph Posted January 13, 2015 Author Report Share Posted January 13, 2015 Next will be using this on the floor, have used in couple friends cars and works great. http://www.fatmat.com/shop/100-sq-ft-fatmat-bulk-pack-install-kit-included-6573 and in a week or so i should have the wiring done and fuel lines ran so i can get ready to start it. (still need to save for a Can-am box from Icehouse) Quote Link to comment
Josh K. Posted January 13, 2015 Report Share Posted January 13, 2015 Looks Good!! Glad I had an extra set :) 1 Quote Link to comment
jeph Posted January 15, 2015 Author Report Share Posted January 15, 2015 Got my pinion gear in today that i had my buddy order a while ago was on back order at nissan and finally came in! just gotta order the new speedo cable now so everything can work properly Quote Link to comment
q-tip Posted January 15, 2015 Report Share Posted January 15, 2015 If you have each end of said cable Tacoma speedometer can make you one. 1 Quote Link to comment
jeph Posted January 15, 2015 Author Report Share Posted January 15, 2015 If you have each end of said cable Tacoma speedometer can make you one. cool ill look into that their over off of steele st by the freeway right? Quote Link to comment
