datsunfreak Posted December 3, 2014 Report Share Posted December 3, 2014 going to make it match the passenger side. Good. I hate seeing people make a nice smooth engine bay and leave that there... :rofl: 1 Quote Link to comment
r0p0doe Posted December 3, 2014 Report Share Posted December 3, 2014 Oh and also Yesterday was me and my girlfriends 5 years together and i asked her to marry me and she said yes :thumbup: :confused: say goodbye to finishing this project :bye: lol jk congrats man 1 Quote Link to comment
jeph Posted December 3, 2014 Author Report Share Posted December 3, 2014 :confused: say goodbye to finishing this project :bye: lol jk congrats man haha naw i got lucky and she knows the 510 is first before the wedding :thumbup: 1 Quote Link to comment
jeph Posted December 7, 2014 Author Report Share Posted December 7, 2014 did a little more work on the 510 today looks like because of the size of the radiator i bought theres only one place to mount the intercooler without cutting everything which i dont really want to do. (cleaned off some of the loose undercoating and sprayed it with new undercoat.) (finally got around to drilling out the front piece to clean behind it.) I need to shim the spacers they welded to the radiator so it will sit closer theres 3/4 inch gap with it bolted in Intercooler is going to go here instead of the grill and the charge pipes will just go threw the high beam holes so i dont have to cut anything. 1 Quote Link to comment
datsunfreak Posted December 7, 2014 Report Share Posted December 7, 2014 FWIW, I had the same size intercooler on a 510. I mounted it down low (upside down from how you have it) and cut the valence to fit around it, then ran the charge pipes along the frame rail and up through where the horns used to be. BRE spook covered the bottom half inch, and the bumper covered a bit in the middle, stopped just under the lower grill trim. I thought it looked cool, and wasn't too tough to do. Quote Link to comment
jeph Posted December 7, 2014 Author Report Share Posted December 7, 2014 FWIW, I had the same size intercooler on a 510. I mounted it down low (upside down from how you have it) and cut the valence to fit around it, then ran the charge pipes along the frame rail and up through where the horns used to be. BRE spook covered the bottom half inch, and the bumper covered a bit in the middle, stopped just under the lower grill trim. I thought it looked cool, and wasn't too tough to do. nice you have a pic of it mounted? The sucky part is the lower valences are getting hard to find and id rather not cut it up at all since its in decent shape. Quote Link to comment
datsunfreak Posted December 7, 2014 Report Share Posted December 7, 2014 The sucky part is the lower valences are getting hard to find and id rather not cut it up at all since its in decent shape. That's precisely why I took mine off, stuck it on a shelf, bought a new fiberglass valance, and cut it. ;) nice you have a pic of it mounted? Sadly, that was about ten years and 4 computers ago... :rofl: I still have a pic of the way I did the cuts on the valance, if that helps. Quote Link to comment
jeph Posted December 10, 2014 Author Report Share Posted December 10, 2014 Got some work done today i sprayed the bay with primer filler after i finished some bondo. Also have a question does anyone know where i can get new bushings for the pitman arm? Quote Link to comment
Josh K. Posted December 10, 2014 Report Share Posted December 10, 2014 http://www.ermish-racing.com/online-store 1 Quote Link to comment
jeph Posted December 10, 2014 Author Report Share Posted December 10, 2014 http://www.ermish-racing.com/online-store Thanks man! you think anyone has ever pressed a bearing into both sides with like a sleeve in the center? i feel like it would be way easier to steer. Quote Link to comment
q-tip Posted December 10, 2014 Report Share Posted December 10, 2014 You want to use bushings in this case because a bearing would transfer vibration. 1 Quote Link to comment
Josh K. Posted December 10, 2014 Report Share Posted December 10, 2014 I obviously make all my own shit.... But... In this case I would just buy Troy's kit. It's well designed and ready to roll :) 1 Quote Link to comment
Spoona_Jay21 Posted December 10, 2014 Report Share Posted December 10, 2014 Progress looks great! can't wait too see the end product! 1 Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 I obviously make all my own shit.... But... In this case I would just buy Troy's kit. It's well designed and ready to roll :) im going to order troys aftermarket bushing he made with needle bearings on each end of the bushing seems like it would work great and 85$ isnt bad at all. Progress looks great! can't wait too see the end product! Thanks a lot! Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 got some new goodies in today from summit! I cant believe i was driving the car around with these old bearings some are bone dry rusted and dont move for shit. Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 also got a question you guys may be able to answer. ive mostly worked on hondas and acuras my whole life so not sure if this would be the same. I took the front struts apart and on these shocks when you push it down it should come back up by itself right? because they dont and they are easy to compress only need like 2 fingers to press it down. also the housings are 12.5 inches long but one had a spacer under the cap holding it in and the other one did not.. Quote Link to comment
datsunfreak Posted December 11, 2014 Report Share Posted December 11, 2014 I took the front struts apart and on these shocks when you push it down it should come back up by itself right? Gas shocks pop back up. Oil shocks often do not. they are easy to compress only need like 2 fingers to press it down. This is not a good sign. 1 Quote Link to comment
q-tip Posted December 11, 2014 Report Share Posted December 11, 2014 They should come back up and also should require most of your body weight to compress it 1 Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 okay so they are blown for sure then. so the shocks i have the body measures 12.5 and the only shock on the guide i found on here that is close to that is this 1982 Volkswagen Rabbit (front) Monroe part# 72878Body type: T2Body length: 12.750"Compressed length: 14.125"Extended length: 20.125"Travel length: 6.00" since mine had washers holding them in these should fit im thinking. Quote Link to comment
q-tip Posted December 11, 2014 Report Share Posted December 11, 2014 Shortened stock or zx housings? Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 Shortened stock or zx housings? its not vented rotors so im assuming stock and has the crazy looking calipers that swivel with the crooked pads lol. Quote Link to comment
q-tip Posted December 11, 2014 Report Share Posted December 11, 2014 Stock for sure, I'm going to assume they have been shortened, the rabbit insersts should work. 1 Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 Stock for sure, I'm going to assume they have been shortened, the rabbit insersts should work. okay cool ill order a set thanks a lot, shouldn't this car have bump steer spacers since the struts have been shortened? if so is there something i can measure to see what size spacers to use or is there only one size. (Sorry for all the questions lol) Quote Link to comment
Josh K. Posted December 11, 2014 Report Share Posted December 11, 2014 Bump steer spacers are to correct the steering geometry after lowering. Since you shortened your struts you'll need spacers. I think I have a spare set.. 1 Quote Link to comment
jeph Posted December 11, 2014 Author Report Share Posted December 11, 2014 Bump steer spacers are to correct the steering geometry after lowering. Since you shortened your struts you'll need spacers. I think I have a spare set.. nice if you could pm me a price i should be able to get them payday thanks! Quote Link to comment
