hobospyder Posted May 29, 2015 Author Report Share Posted May 29, 2015 visited little miss and the mechanic today. paid for the dizzy that the mechanic is waiting on, ordered off of rock auto. choke is wired in, i was close, just wrong wire. hopefully the dizzy arrives on tuesday like it's supposed to. i need a couple days to be able to drive little miss to work and put some gear oil in before canby 1 Link to comment
hobospyder Posted May 29, 2015 Author Report Share Posted May 29, 2015 So, my knowledge is about tapped out. I was pointed towards isky cams since I need a new one and there's five to choose from for the 4 cyl l motors. I'm overboring a l20b to make a 2.3, any advice on which one I should get? Also is there any difference between ka24e and ka24de pistons and which set would be a better choice? Link to comment
hobospyder Posted May 29, 2015 Author Report Share Posted May 29, 2015 Ok, my mechanic answered the question on which cam to get. I think I'm going to get the ka24de pistons which are rated for higher compression (i think) and see what happens 1 Link to comment
hobospyder Posted May 29, 2015 Author Report Share Posted May 29, 2015 Gaskets, pistons (and rings) and cam shaft ordered. Now, I wait.... 1 Link to comment
hobospyder Posted May 30, 2015 Author Report Share Posted May 30, 2015 GasketS: Pistons: Stuff actually happening but new motor won't be built until after Canby. Wish I could be ready to paint the engine bay while the motor is out but I won't be. Gonna switch to el dizzy and a larger alternator when I do the swap though. After motor is built and in I'll start looking at exhaust and get that upgraded and shit can the cherry bomb or whatever resonator the po put on it. I want a quiet truck 1 Link to comment
hobospyder Posted June 2, 2015 Author Report Share Posted June 2, 2015 To my chagrin Little miss is still at the mechanics waiting for the dizzy which should arrive today. In preparation for getting her back I picked up oil change supplies and forgot about the gear oil for the tranny because I'm an idiot. Is it the same as the gear oil for the rear diff? If so I already have some but I'll figure that out later. Pic because I got the right stuff this time. And of course a wix oil filter using the one that is already on as reference Reference picture Also, do people look at the tracking information for parts as often as I do or am I getting overly watchful on these things? One package supposed to arrive tomorrow, another on Friday and isky is still processing my order from Friday. Going crazy on the isky one..... Link to comment
abbylind Posted June 5, 2015 Report Share Posted June 5, 2015 According to Dr Mike GL-4 for the tranny and GL-5 for the differential Link to comment
hobospyder Posted June 5, 2015 Author Report Share Posted June 5, 2015 According to Dr Mike GL-4 for the tranny and GL-5 for the differential ok now that i went to the garage and looked at what i have for the diff, this makes sense thank you Link to comment
67_1600 Posted June 5, 2015 Report Share Posted June 5, 2015 You may have been planning to already, but I highly recommend you get everything balanced including your flywheel and damper/pulley (also send your flex plate). I had mine done recently and my flywheel was off by 186 grams and my pulley was off by more than 48. The place balanced everything and marked it all so I line everything back up for the best balancing when I put it back together. 1 Link to comment
]2eDeYe Posted June 5, 2015 Report Share Posted June 5, 2015 According to Dr Mike GL-4 for the tranny and GL-5 for the differential You can run GL4 in either. The GL5 has stuff that has been now to deteriorate the syncros in the transmission. :) Link to comment
hobospyder Posted June 5, 2015 Author Report Share Posted June 5, 2015 You may have been planning to already, but I highly recommend you get everything balanced including your flywheel and damper/pulley (also send your flex plate). I had mine done recently and my flywheel was off by 186 grams and my pulley was off by more than 48. The place balanced everything and marked it all so I line everything back up for the best balancing when I put it back together. how much was it if you don't mind me asking. That's right in the middle of my commute 1 Link to comment
67_1600 Posted June 5, 2015 Report Share Posted June 5, 2015 My brother said they'd typically charge $225 for a full balance like that. I had sent the crank, all of the rods and pistons with pins plus the damper, flywheel and flex plate. I don't know if Perpetual Balance works directly with the public or just as a service for different shops in the area, but it never hurts to ask. 1 Link to comment
hobospyder Posted June 5, 2015 Author Report Share Posted June 5, 2015 My mechanic has a "shop" in Arlington, it's where little miss is right now. I could probably have him send it in for me. I know he's got a machinest for me to send everything to but it'll be nice to know that the rotating masses are balanced 1 Link to comment
hobospyder Posted June 7, 2015 Author Report Share Posted June 7, 2015 Stuff came in. Now to get on my mechanic about little miss 2 Link to comment
hobospyder Posted June 8, 2015 Author Report Share Posted June 8, 2015 Went to help with the dizzy today And brought her home instead Love the views I get out of my living room window this weekend And after dinner I'm going to change her oil. Because I figured yall might like, one of my mechanics hats 2 Link to comment
Draker Posted June 8, 2015 Report Share Posted June 8, 2015 Lookin good man. Nice parts stash 2 Link to comment
uberkevin Posted June 8, 2015 Report Share Posted June 8, 2015 Stuff came in. Now to get on my mechanic about little miss What are the pistons? And where'd you get? 1 Link to comment
hobospyder Posted June 8, 2015 Author Report Share Posted June 8, 2015 What are the pistons? And where'd you get? ka24 pistons off of eBay. Please hold 1 Link to comment
uberkevin Posted June 8, 2015 Report Share Posted June 8, 2015 Doesn't look like the ones I used.. and set I have in box.. that why I ask 1 Link to comment
hobospyder Posted June 8, 2015 Author Report Share Posted June 8, 2015 Changed the oil 2 Link to comment
hobospyder Posted June 8, 2015 Author Report Share Posted June 8, 2015 Doesn't look like the ones I used.. and set I have in box.. that why I asklook at your phone 1 Link to comment
uberkevin Posted June 8, 2015 Report Share Posted June 8, 2015 So guys ka24DE pistons in a l20b??, u67 head? Are you putting bigger valves in your head? 1 Link to comment
hobospyder Posted June 8, 2015 Author Report Share Posted June 8, 2015 Are you putting bigger valves in your head? was thinking about it 1 Link to comment
67_1600 Posted June 8, 2015 Report Share Posted June 8, 2015 Doesn't look like the ones I used.. and set I have in box.. that why I ask That dish in that piston does look huge. The standard KA24 piston should have a 2.8cc dish. The dish on that makes it look like it could be a Z24 (15cc). 1 Link to comment
uberkevin Posted June 8, 2015 Report Share Posted June 8, 2015 This is what I used. 1 Link to comment
