TENDRIL Posted April 12, 2014 Report Share Posted April 12, 2014 they are the same, one just has the "matchbox" mounted to the body of the dizzy Quote Link to comment
datzenmike Posted April 12, 2014 Report Share Posted April 12, 2014 Often the dizzy is grabbed and the remote igniter box is forgotten or lost. If you get one like this you can swap to a matchbox or add a Chevy HEI module. Either way they both work and do the same job. Quote Link to comment
Curt Posted April 12, 2014 Author Report Share Posted April 12, 2014 Ok, I understand. I was curious why you changed yours from the remote module EI, to the matchbox EI distributor with the distributor mounted module. Was it just for a cleaner look? Or is there other performance benefits of the matchbox over the remote mounted module. Quote Link to comment
laotsu Posted April 12, 2014 Report Share Posted April 12, 2014 no performance benefit upgrade per se but some people do worry aboot the matchbox being angled towards the exhaust manifold and rotate their oil pump spindle 180 to protect it. Personally I run mine unrotated and have never had a problem, but then again the longest I have driven Ol' blue is 200 miles at one time. Quote Link to comment
banzai510(hainz) Posted April 12, 2014 Report Share Posted April 12, 2014 http://www.olddatsuns.com/620tech.htm read carefully its in here ignition section 1 Quote Link to comment
banzai510(hainz) Posted April 12, 2014 Report Share Posted April 12, 2014 as for the vaccumstament of dizzy worn out. I had one that was rock solid. I just adv ance or retarded the dizzy to my main driveing prefernce to get by untill I got another dizzy. worked fine Quote Link to comment
laotsu Posted April 12, 2014 Report Share Posted April 12, 2014 http://www.olddatsuns.com/620tech.htm read carefully its in here ignition section bunch of the links and pdfs are dead these days... ditdnt somebody else take over hosting? Quote Link to comment
ggzilla Posted April 12, 2014 Report Share Posted April 12, 2014 And that's why its better, to get the matching pedestal and timing plate. It'll be rotated away from the hot manifold. Get L20B distributor for L20B, L18 or L16 engines. Z20 4-plug distributor will work but doesn't bolt in with same rotation. no performance benefit upgrade per se but some people do worry aboot the matchbox being angled towards the exhaust manifold and rotate their oil pump spindle 180 to protect it. Personally I run mine unrotated and have never had a problem, but then again the longest I have driven Ol' blue is 200 miles at one time. Quote Link to comment
laotsu Posted April 12, 2014 Report Share Posted April 12, 2014 Hmmmm? I guess I have a z dizzy Quote Link to comment
datzenmike Posted April 12, 2014 Report Share Posted April 12, 2014 Hmmmm? I guess I have a z dizzy Still will work. Drop the oil pump spindle and clock it around so the vacuum advance does not hit the thermostat housing and the matchbox is, more or less, away from the hot exhaust. I've sold one Z20E matchbox and given the other away. Quote Link to comment
laotsu Posted April 13, 2014 Report Share Posted April 13, 2014 I've been running it up against the exhaust manifold for four years with no problems... JINX! Quote Link to comment
