heartsandhotrods Posted April 7, 2014 Report Share Posted April 7, 2014 Lately my 810 Datsun 1983 has been slow on shifting into gear after sitting at a light ..could it be my transmission? any thoughts? Thnx Quote Link to comment
MicroMachinery Posted April 7, 2014 Report Share Posted April 7, 2014 Yes. Auto, right? Quote Link to comment
MikeRL411 Posted April 7, 2014 Report Share Posted April 7, 2014 Check the automatic transmission fluid level when it's hot. Bet it's low, Biennial service seems due! Quote Link to comment
ggzilla Posted April 7, 2014 Report Share Posted April 7, 2014 Normally it stays in gear at stop lights. Are you manually shifting into Neutral, and the back into Drive when the light changes? Quote Link to comment
datzenmike Posted April 7, 2014 Report Share Posted April 7, 2014 Lately my 810 Datsun 1983 has been slow on shifting into gear after sitting at a light ..could it be my transmission? any thoughts? Thnx Need more info. This a standard transmission? I shift into neutral at stop lights to preserve the release bearing. If hard to shift into gear then I would check the clutch master hydraulic fluid level. Its just to the right of the brake master cylinder booster when viewed from the front of the car. If low, topping it up and or bleeding it may help. Quote Link to comment
sal Posted August 3, 2014 Report Share Posted August 3, 2014 If master and slave cylinders are working properly then your synchronizers are bad. if automatic check the fluid level if ok then try to do an oil change if still have problems then take it apart may be a solenoid or friction material gone from clutch disks Quote Link to comment
