thisismatt Posted April 5, 2014 Report Share Posted April 5, 2014 Don't go through any hard dips too fast. That is, if you want your doors to continue opening :P Quote Link to comment
510BRI Posted April 5, 2014 Author Report Share Posted April 5, 2014 Don't go through any hard dips too fast. That is, if you want your doors to continue opening :P Im in the works to getting more support to the front. Hopefully will prevent that from happening. :thumbup: Quote Link to comment
510BRI Posted April 8, 2014 Author Report Share Posted April 8, 2014 Got a core support today. did a little mock up. looks a lot better. 2 Quote Link to comment
510BRI Posted August 22, 2014 Author Report Share Posted August 22, 2014 cut out the old support and put in a new core support. wrapped the dash pad. have been collecting some parts. hopefully have the car running next week. :thumbup: Quote Link to comment
q-tip Posted August 22, 2014 Report Share Posted August 22, 2014 Already looks better 1 Quote Link to comment
twistedimages Posted August 22, 2014 Report Share Posted August 22, 2014 Looks like a fun project! As others have said, try to get some sort of cage in there to keep it from folding up. Other than that, enjoy it! I have a shop in Sacramento- if you need any steel parts cut or bent for it just let me know! 1 Quote Link to comment
datzenmike Posted August 22, 2014 Report Share Posted August 22, 2014 The roof provides structural support and rigidity. Well, do the best you can As much as I hat roll bars, this needs it. Not for rolling but to reduce chassis flex. This will be a wet noodle without it. Quote Link to comment
banzai510(hainz) Posted August 22, 2014 Report Share Posted August 22, 2014 Get a Samoan to sit in car. if door dont shut right then you need to reinforce the underside so car dont flex. Mine is from the rear wheel well to c pill then to front then a sub frame under neath to keep car from flexing Quote Link to comment
Dime Dave Posted August 22, 2014 Report Share Posted August 22, 2014 There was a red one around that Scott over at Import Tuner mag cut up and used for parts on their 510 build. The first segment is in the Aug/Sept '14 issue. Quote Link to comment
Z chopper Posted August 22, 2014 Report Share Posted August 22, 2014 I have seen roll bars that have bars that go forward that are just about the same height as the seat bottom, Quote Link to comment
510BRI Posted September 1, 2014 Author Report Share Posted September 1, 2014 new shoes, new seats (new to me) 1 Quote Link to comment
