difrangia Posted March 31, 2014 Report Share Posted March 31, 2014 Are the B210, 210, and 310 standard transmissions interchangable? Steve Quote Link to comment
ggzilla Posted March 31, 2014 Report Share Posted March 31, 2014 Only the four-speed for A14/A15 interchange. There are several minor differences between the others that prevent a strict interchang, although they can all be swapped. Namely: * gearbox mount location * reverse lamp location * transmission length and output spline * torque rating. The 56 is not recommended behind A14/A15 4-speeds - F4W60 fitted to A14/A15 - F4W56A fitted to A12A The mount points for the crossmember differ 5-speeds - FS5W63A fitted to B210 - FS5W60 fitted to B310 The mount points for the crossmember differ The output spline and length differs 60-series are same length both 4-speed and 5-speed. The output splines are same. Ditto for the lighter 56-series 4-speed. You need to fabricate a mount adapter to swap these in a B210. B310 came with 3 different crossmembers which will bolt to any B310 so factory parts can be used. Quote Link to comment
ggzilla Posted March 31, 2014 Report Share Posted March 31, 2014 Datsun 310 transmissions are FWD, so won't swap with B210 or B310 (badged "210"). Quote Link to comment
