J13 Engine after market parts and all other cross over parts
  • Please log in to reply
52 replies to this topic
#1 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,291 posts
  • Cars:1966 520, 1967 520, 1985 720 ST King Cab, 1986 720 King Cab
Posted 30 March 2014 - 03:45 PM
Here are some intake manifold and header options
              Description                   Part #         Price              Vendor
Weber DGV & Econo Intake       P17-001     $315.95     Pierce Manifolds
http://www.piercemanifolds.com/product_p/P17-001.html
Weber DGEV & Econo Intake     P17-002     $315.95     Pierce Manifolds
http://www.piercemanifolds.com/product_p/P17-002.html
Patriot/Exhaust Header              H4800-1     $205.99      Autozone
http://www.autozone.com/autozone/parts/_/N-a033t?itemIdentifier=403607_0_0_
MGB Headers                             31-4576     $145.00     Pierce Manifold
http://www.piercemanifolds.com/product_p/31-4576.htm
Canon Intake Manifold              2802
Some Links to Ratsun's fabricators custom Parts.
Mike Klotz
MKlotz Disc Brake Kit for King Pin Trucks
MKlotz Disc Brake Kit Instalation
MKlotz Master Cyl Upgrade Push Rod
MKlotz Z LCA 2 Iinch Drop for King Pin Trucks
MKlotz UCA Bushings
Beebani
Beebani Hardbody Disc Brake Brackets for 620 521 520 320 Trucks
Beebani 620 Coilover Mounts
Please add more links if for different parts.
#2 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,133 posts
Posted 30 March 2014 - 03:59 PM
#3 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,904 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 30 March 2014 - 04:05 PM
For 520 and L521s
Posted Image
#4 MikeRL411
MikeRL411
    78 'n counting...
  • Senior Member
  • PipPipPipPipPip
  • 5,376 posts
  • Cars:67RL411, 90 240SX, 97J30T
Posted 30 March 2014 - 05:16 PM
For 520 and L521s
And PL411.
#5 fatphos
fatphos
    Newbie
  • New Members
  • Pip
  • 4 posts
  • Cars:1966 Datsun 520
Posted 31 March 2014 - 02:29 AM
Good stuff! It'll help those in the future for sure!
#6 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 514 posts
Posted 06 April 2014 - 09:54 PM
I believe others have mentioned header clearance issues with factory fuel pump.  YMMV.
:pirate:  Scrimpin' aint easy
#7 highdesertdatsun
highdesertdatsun
  • Senior Member
  • PipPipPipPip
  • 325 posts
  • Cars:63 C10 66 520 68Xr7 68 goon 87K5 91V3500
Posted 07 April 2014 - 02:11 PM
tri mill header part#4576 avail from JT outfitters Danbury North Carolina
it apears to have ample clearance of fuel pump and torsion bar. $133.00
"It's the bizarre idiots that act smart."
#8 highdesertdatsun
highdesertdatsun
  • Senior Member
  • PipPipPipPip
  • 325 posts
Posted 08 April 2014 - 10:23 AM
WEBER PROGRESIVE CANNON INTAKE #99003.803 HAS A COOL HEAT EXCHANGER THAT USES THE HEATER HOSE WE ALL REROUTED .
#9 highdesertdatsun
highdesertdatsun
  • Senior Member
  • PipPipPipPip
  • 325 posts
Posted 08 April 2014 - 11:41 AM
completed today . installed standard modern type seal into front cover by grinding away the outer
lip that retains the felt seal. leaving the inner welded on flange. this must be done slowly so not to
take off to much material. order a seal # 1213n timken or cross it . i tried to find one with rubberized coating but failed . i also put a very small bead of grey silicone around inner flange
to seal againts the new seal . a friend has done this with sucess on a daily driver. mine came out well
have yet to install.
#10 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 514 posts
Posted 08 April 2014 - 12:06 PM
I didn't see anything like this on JT Outfitters site.  Here's what Tri-Mil lists for Datsuns... http://www.tri-mil.c...ex.php?cPath=21 ... all L-series motors.  Have you got a link to the header you posted?
#11 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,291 posts
Posted 08 April 2014 - 07:59 PM
Good info guys keep up the posting..  Mos tlikely i know the parts I listed as with others will take a little tweaking to fit properly but these do provide an option.
As far as doing business with Pierce Manifolds they are a top notch dealer. I have ordered from them for over a decade and not 1 problem.
#12 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,291 posts
Posted 09 April 2014 - 01:41 AM
I used these instead of stock on my 1966 520. Not sure if they are legal where you are. These are DOT approved and only draw 10 amps each on brights turning on and 5 amps each continuous.  No, stock wiring changes needed, but I would go ahead and wire in relays for at least the high beam circuit and another for the low beam circuit.  These are glass faced and closely match the curvature of the stock sealed beams.  I would order an extra set of replacement bulbs other than the Hella's as the Hella's seam to not last long.  Also your stock headlight plugs, plugs into these bulbs.  I am using my stock wiring and plugs, but I have not actually run these lights using the stock Datsun plugs.  I might set up a test with these lights and let them run say 8 hours on high beam and see if it melts the stock plug.  I will edit this post after I run this test.
http://classicgarage...l7rounh4he.html
My 520 light buckets with the Hella's installed
#13 highdesertdatsun
highdesertdatsun
  • Senior Member
  • PipPipPipPip
  • 325 posts
Posted 09 April 2014 - 07:44 AM
XXL the intake & header listed I purchased from ebay . the header was from JT . they are listed as a mg or mgb or austin performance parts.My header may need a slight adjustment at fuel pump. i may put header wrap on it aswell. I like cool fuel .
#14 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 514 posts
Posted 09 April 2014 - 07:49 AM
10A each???  That's 120 watts per bulb.  Are you sure?  Most high beams are in the 55-65 watt range.  At 5 watts, low beam is 60 watts... also, very high for a low beam, which is typically 45 watts.  Just asking.
#15 ggzilla
ggzilla
    Road Warrior
  • Senior Member
  • 19,058 posts
  • Cars:no cars
Posted 09 April 2014 - 10:29 AM
Hella make high-power, non-sealed bulbs. Takes a lot of power.
Here today gone tomorrow
#16 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,291 posts
Posted 10 April 2014 - 12:28 AM
2 High beams 10 amps at start at time bulbs light then draws 5 amps.  2 low beams start at about 8 amps and then draws continuous 4 amps. The Hella Bulbs that shipped with the glass housing are as you said 55 to 65 watts which is DOT legal.
Did this last night when I could not sleep.
Thank you for questioning me.
This I have actually tested.
  • XXL likes this
#17 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,291 posts
Posted 10 April 2014 - 12:32 AM
Yes Hella makes high power non DOT approved bulbs that you can buy but these are 55 to 65 watt bulbs.  Check the link for the Hella bulbs and you will see the variety of colors available.  Also states the wattage.
#18 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,291 posts
Posted 04 May 2014 - 09:44 AM
Yello620 committed on another forum That he used these on his C10 pickup and within 5000 miles the headlight plugs melted.  After reading this I realized it is not the amperage draw but the heat generated from the halogen bulb that melts the plugs.  I am going to go ahead and purchase the ceramic plugs for the halogen bulbs and wire in 2 relays to protect my wiring.  I will do a write up when I do this.
Thank you yello620 for you information.
http://www.buy4car.c...-1645-2149.html
http://www.amazon.co...s/dp/B0097AA478
http://www.amazon.co...t/dp/B00AQBATVI
#19 KFunk740
KFunk740
    Advanced Member
  • Members
  • PipPipPip
  • 275 posts
  • Cars:1965 Datsun L320, 1974 BMW 2002, 1992 Mazda Miata, etc.
Posted 16 May 2014 - 11:19 AM
Anybody know of a good source for a fuel pump heat shield?  I'd rather not fabricate my own and have it look like crap, and I looked up the Nissan part number and can't find it available anywhere.
It's getting embarrassing to have it struggle starting on hot days, right after someone is asking me questions about the truck.
#20 ggzilla
ggzilla
    Road Warrior
  • Senior Member
  • 19,058 posts
  • Cars:no cars
Posted 16 May 2014 - 11:50 AM
Have you seen the stock heat shield? It looks homemade. You can make a nicer one.
