Style23's 71 510 Wagon Project
Alright, figured it was time to start this as parts are starting to come in. Will be a long project but after waiting 3 years for the car whats a couple more right?
Rough ideas i have in my head: Low and go.
-Built Ka24de-t
-ford 9" aluminum rear w/ coilover 4 link
-15x10~12 watanabe's....i want 12" wide but finding tires is proving to be difficult, so still not 100% sure
-15x8 watanabe's on the front
-wilwood's in all 4 corners
-several chasis stiffening methods...stitch welding, high density foam in the body cavities, butterfly brace
-planning on canteen green paint off of the nissan titan
car will be configured as a street/strip car mainly, but dont want to exclude myself from a weekend warrior road course. And definately dont want to ruin the character of the car.
for right now my plans are get the L16 running, so i can tool around in it as i wish, until i am ready for the motor swap.
parts either in the garage or on the way as of 3/22/14:
Techno Toy Tuning 280zx strut casing front coil overs with 225# springs
Arizona Z Car 12.2" 2 piece rotors with wilwood 6 piston calipers
Arizona Z Car 5 lug conversion
2" rear block kit
I had the car up and running about an hour after i started working on it, bled the brakes and was cruising around the neighborhood. Took it out and got it up to 50 and had a bit of a spit and sputter at high end, so i stopped at the store, adjusted the carb a bit, cranked it up 15 minutes later and was running fine til i pulled out of the parking lot. Made it about 60 feet before it died, and wouldnt run. When i got it to run i had to keep my foot in it and would backfire like crazy. Called a friend to pick me up to get my truck and towed it home. Hasnt ran since, which was about 3 weeks ago. Im open to suggestions as to what it could be. so far i have replaced the entire carb instead of rebuilding it, fuel filter, spark plugs, wires, cap and rotor, ignition coil.
The plugs are very sooted after trying to get the car running, so not sure what im doing wrong.
as of right now i am in the process of taking the front of the motor apart to get to the timing chain, because i figured that was my next logical step, and from what i can figure out it is off. I am guessing i jumped a tooth or something when i was testing it, thus why it ran fine, and hasnt ran since.
I know next to nothing about carb cars, because everything ive worked on has been fuel injection, so i am learning a lot as i go. My dad is coming over tomorrow to give me a hand in figuring out what i dont know about timing, etc...
I always welcome constructive critisizm, so if you have any suggestions or ideas please dont be shy.
But picture time, some of these are reposts:
hauling it home from dallas to houston, stopped at whataburger for a snack after a 16 hour work day:
F82B3A2C-7CCB-4BEF-8D66-E761E5CCE3DD_zps
Its new home:
DD47010A-B0E1-4DB7-B32C-DB64505DB38F_zps
22BDAE8F-CD0C-42B0-91F7-D890C1D72AB9_zps
147A4C4E-DEE4-4C21-9EB4-A4AAAEEEEB1C_zps
running and ready for a spin:
593E66A8-925E-407E-9A9D-EE560E4767EA_zps
And, back to the drawing board:
D976D751-01C5-44C7-B55A-6CD4C0860B04_zps
B1D9D4A5-460B-4777-BFA6-2BE55691AABB_zps
2BC4780E-C65E-40E8-83C5-F8C2058CCB35_zps
And the toughest part of the body work, the rear passenger quarter has at the thickest i found about 3/8" of filler in it:
4FC097CA-C3BC-4E5C-A3D9-27A454AA9E8B_zps
A6ACD62F-945E-43A0-A816-59D3C477EEA0_zps
08A949E6-E262-4F57-B1D1-30236AF55D67_zps
  • Replies 41
no pictures today, but the timing chain did the trick...old chain had been adjusted all the way out and was still off...so got the car back together and it is running, but now it ran long enough for me to notice the alternator isnt charging at all.
Yea the rear quarter is pretty rough...from what I gather the rust is because of the bad respray to cover up the body work right next to the rear door.
I've looked at 2jz's wagon a lot but it will be a bit different. I plan on doing a tub...I really wanted 12" wide but can't find the tires to match..
Hobbes, I will shoot him a message and see...the bottom kick panel is dented a bit so not sure how to fix that. I may end up going a bit different route, ratsun instead of full body work and resto. Weighing my options still.
small update: new alternator in, and learned the hard way there is a thing called a voltage regulator on old cars...hooked up the battery and got an arc and the starter started smoking. hopfully i didnt fry anything but this learning thing is getting expensive...new voltage regulator on the way.
in other news, i found a company that will cover the car as a classic if anything were to happen so i dont get blue book value on it. Will give me $10,000 of coverage that i can up as the project progresses. Game plan is to have it insured tomorrow so i can get the registration done on wednesday when i go to the DMV to correct the title they spelled my name wrong on. Inspection on friday, and hopfully legal by the weekend. One of the stipulations of insurance is i need to submit detailed pictures of the car, so i rolled it out on the driveway a bit to get it in the daylight, so i have decent pics to show, everyone likes pics:
D36B7255-FE17-459A-A6D0-80285430B19E_zps
A160A48E-901A-4F1A-832A-41E4BE3858DA_zps
74A69AFE-5AD5-4296-81EA-C6A07CE678AB_zps
E4F5224D-4815-4880-A79E-24D711EB2786_zps
2F01F5D3-7910-4E82-BE97-C99F31CE4124_zps
4BC8A472-FA0A-4D4A-9A5C-618C143C5879_zps
D527929A-E209-403A-BC6F-42A5B4F23747_zps
3C9DD6A4-DA6F-4CF3-99FA-B3689C0E3B14_zps
67D71752-2EEF-4AB7-9E09-6C643093FFA7_zps
D0C02E76-8BD3-4E39-908F-8ADE36C1269E_zps
PS....found a cool gauge option, i was looking for something digital i could blend with the factory dash but give me much more readouts so i didnt have to plaster gauges all over the place...i found this:
i am officially naming this build B.O.A.T - bust out another thousand.
few small updates, i got the new alternator and voltage regulator in, and is charging properly. Have the car registered and insured. Took it a mile down the road to get some gas and by the time i made it to the gas station i had a very loud valve noise and it was smoking badly. After investing $400 in the temporary motor i have decided to cut my losses and move forward with the new motor sooner then planned. So i will be trying to sell the engine to recoup some of what i have invested.
On other news my calipers showed up today for my brakes, but am waiting for a call from UPS to pick up the rotors and 5 lug hubs. Unboxed the calipers and they dont match, the writing is different as you can see in the picture. Not a huge deal to most probably but i am all about the little details, and with dropping the money i did on the brake kit, it has to be perfect. Also noticed the calipers have some damage to the finish on them, looks like they have just been floating around the shop and have misc. scuffs and scratches on them. Nothing major by no means, and would be able to deal if they matched. I know they will get scuffed up eventually, but i want to be the one to scuff them. I called and spoke with Dave(i think?) at arizona z car and he didnt have a problem with me sending them back to get matching calipers.
10FA7529-A0BD-4C23-8939-D6E9D68AFA08_zps
240C821B-09F0-4D23-9389-9350701A7FBE_zps
Nice goon. Bummer about the lettering on the calipers.  I think the "boat" name is awesome, but for most of us around here it would just be another 10 :thumbup:.
If you have no plans for the steel wheels and hub caps, I would be interested.
Kelmo I don't have plans for them but it will be a little while...I'm looking for cheap 5 lugs that will fit the car to use u til I'm ready for the final wheels...
My macho bigger is better may have bit me in the ass...realized last night that my dreams of 15" wheels are crushed and it's not looking good for 16 either. I may have to downsize to 4 piston calipers, I will have to bolt them up and measure.
Better news is I picked up my rotors and hubs from ups today...
5D0EDA8B-336C-455D-A64F-1BC485FE248D_zps
Yeah I was about to say, the AZC Wilwoods require 17's.  The 4 piston AZC kit should be more than enough though.  Hell, even 280zx fronts/stock drums feel awesome in mine.  I do eventually plan on getting some Wilwood bling though.
And from what I've read/been told, the chassis stiffening foam is a bad idea.  It works well, but if it rains and water gets trapped, the foam is going to make it hard for it to drain from whatever cavity it is in.
I bet they've sent that unmatched wilwood a few times, always getting it returned. That's why it's all scratched.
I love the brown interior with green. Classy. And 10" is plenty. Lots of work on the wells just so you can spend more money on tires is not necessary. I say build with 10's and if you spin those, you can always go bigger.
Thanks for the words everyone...im getting frustrated that i picked the wrong brake setup and am trying to figure out what to do to correct it. Im so confused as to what the right choice is with this, now knowing i for sure should go with 4 pistons instead of 6...not sure that the 12.2" rotor was a good choice either, thinking maybe i should have done an 11"
on the chasis foam, that is something i had considered, so i planned on welding up all the holes in the cavity to try to seal out moisture, but that could cause potentially more problems with moisture sealed in there...im a ways away from that point, so it will give me some time to do more research on it...the car wont really be setup to drive in the rain but in Houston we get freak showers all the time.
I saw your L16 listed on Craigslist.  Did you find another engine for it yet? or are  you just pulling the L16 to raise funds for the future swap?
I find that I work on my cars that run more often than the ones that don't.  It's always fun to go for a test drive when celebrating a victorious part changing.
i dont have another engine for it yet, i much prefer to have a running vehicle, but it is part of the process i suppose...will free up the engine bay for me to clean it up while i wait i suppose...i think i talked myself into an SR even though i was so against them for so long. If that is the case it will be a little while longer before the new motor will be here and ready to go in.
havent made much progress lately...work is slow so not much cash to throw at the project right now, have to love the oilfield...got the shipping conformation from techno toy tuning, they shipped my coilovers yesterday, 2 weeks late, but they are on their way.
pulled the engine, managed to do it in about 3 hours by myself, not to shabby for my first engine pull ever, and no major problems at all...motor is out and ready to sell.
Ready to party:
8E3C6431-E111-4F41-AF83-DEE116454AB2_zps
Almost forgot the most important tool:
81741E46-6E35-49DE-9652-53D7773D68E2_zps
made a solid 18% of the fluids into the pan:
D70A0900-2E06-4EBA-98C8-A87292DEA580_zps
66B0961F-03A3-416E-8398-B6CA145F2A1D_zps
5B700DB4-275B-4A69-93E7-C49D07ADC46E_zps
D64580BC-3A2D-41B6-9D7F-E767C0245BF8_zps
2635BF7F-E456-4200-A7CE-50594749C0E2_zps
0B13633A-51FA-4EBF-8873-E4955ED0191A_zps
hope you folks dont mind all the pictures...
  • 2 months later...
Finally turned a wrench on the car today for the first time in forever it feels like....totaled my mountain bike, concussion, swollen face, sore shoulder, etc..so used the money i had planned to put towards the motor for the car to buy a new bike. 3 Days after ordering the bike i smoked the turbo in my diesel daily. Drove a rentail Hyundai Elantra for 3.5 weeks...talk about a shock from my 3/4 ton.
Anyway, truck is back up, so got to put my focus back on the car...
got the engine bay mostly cleaned up, almost ready to start media blasting...the game plan is to media blast, stitch weld and prime before the metal starts to rust in the humid houston weather. doing the whole engine bay in a weekend is near impossible by myself in my opinion. So the plan is to do like 1/4 or 1/3 at a time, that way i can ensure the metal isnt exposed to long.
have 80 grit glass bead i will be blasting with, and will be priming with a grey PPG epoxy primer.
KA24DE will be here some time this week, eventually it will be getting a z32 transmission, and a megasquirt engine management system.
32063B08-4B84-4BD0-9673-8000BC954C1D_zps
Also have a few goodies ive been sitting on for a long while waiting for the right project...time to bring this project up to the 21st century. Not a fan of spending all this money building the car and taking the distributor wire with me to prevent theft. Will have full remote start, glass break sensor, digital tilt sensor, engine immobilizer, and the standard bump alarm. Since the ignition on my car is bad and i dont have any keys, i decided to use a push start, since i have the engine immobilizer anyway. Did a little bit of searching and found an OEM push start thats actually out of the nissan GTR. I need to get a wiring harness and trim ring out of a 370z so i can splice in the plug to wiring and mount the button.
AC09A852-09C3-4DDA-B8F4-FA884FB63B40_zps
after the freight company not calling me and letting me know the engine was here 2 days ago, i went and picked it up today...this is my motivation to finish the engine bay...im really dreading body work and paint...
36930D07-5140-437C-90F0-C0F76C2A3970_zps
kind of surprised the cherry picker went up that high, the bed of my truck is up around 4' off the ground.
FFE71ECC-CBB0-4500-A8EC-0C618F3A4942_zps
and note, my driveway truly sucks for trying to pull a cherry picker across it by yourself without swinging the engine wildly.
C10113A2-F30D-4045-8CEB-B5CDC6AA16C9_zps
the project continues.
planned on working on the engine bay all weekend and ended up having to work both days...so sunday about 5pm when i went to get started on it i fired up the air compressor and the auto water drain blew and oring and the tank wouldnt hold air...so in all i got 0 work done on the car this weekend...
but today i picked up a new one, and kind accidetally bought another motor...so now i have 2 ka's. at least i got an ECU, 5 speed trans, and complete wiring harness with this one...although the engine itself is nowhere near as clean.
0F49AD55-054C-4ED8-A6EC-04B97D7D34A1_zps
on a side note, does anyone know what the screws are inside the fenders to remove them? i havent been able to get them off yet, i had assumed they were phillips, but couldnt get any to turn. Im not sure if ive got it wrong or they are just packed full of dirt.
Yes the 2 screws on the front bottom side that you can't see are Phillips. I love we're your wagon is going, I have been getting second thoughts of even finishing my wagon but you just got me motivated again.Watqnbes are a good choice to I have a hook up on a set for 3000.00 or a little less bit they are wide so rear will make fit but front won't work unless I run flares.
